Can a machine be brilliant? The Aspire Switch 10 thinks so. With a LED display that reveals bright colors and crisp, clear text, it delivers a lifelike visual experience.
A spectacular view
With the resolution to bring details to life and the resilience to battle wear and tear, the Aspire Switch 10 is a stunning device you will want to share. -
A mode for every instant
The Aspire Switch 10 is powered by a fast processor and transforms into four distinct modes that enable you to multitask in any environment. Detach and use it as a tablet, get tasks done in laptop mode, pivot its screen to share, or flip to watch a movie when space is limited. -
Acer Snap Hinge
Flip, rotate, or detach in a snap - the Aspire Switch 10's unique Acer Snap Hinge uses the invisible force of magnetism to provide a latch-less docking solution that lets you smoothly remove and re-attach the keyboard to the display.
- Acer Aspire Switch 10 E SW3-013-17ZH - 10.1" - Intel Atom - Z3735F - 2 GB RAM - 32 GB eMMC
- Product Type
- Tablet - with keyboard dock
- Operating System
- Win 10 Home 32-bit
- Processor
- Intel Atom Z3735F / 1.33 GHz, up to 1.83 GHz / 2 MB Cache
- Memory
- 2 GB DDR3L (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 10.1" LED backlight touchscreen 1280 x 800 / WXGA
- Graphics
- Intel HD Graphics
- Input Device
- Touchpad, detachable keyboard
- Integrated Webcam
- Networking
- Bluetooth, 802.11b/g/n
- Battery
- 2-cell - up to 12 hours
- Ambient light sensor, G-sensor
- Dockable
- Black, white
- Dimensions (WxDxH) - tablet
- 26.2 cm x 18 cm x 1.095 cm
- 630 g
- Localisation
- Region: United Kingdom
- Product Type
- Operating System
- Windows 10 Home 32-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 1.83 GHz
- Number of Cores
- Quad-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 2 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 32 GB eMMC
Display
- 10.1" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1280 x 800 (WXGA)
- Widescreen
- Image Aspect Ratio
- 16:10
- Image Brightness
- 350 cd/m²
- HDCP, glare, CineCrystal, Mercury free
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1600 x 1200 (rear), 1600 x 1200 (front)
- Resolution
- 2 Megapixel (rear), 2 Megapixel (front)
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, microphone
Input
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Technology
- 2-cell lithium polymer
- Capacity
- 30 Wh
- Run Time
- Up to 12 hours
- Battery Run Time
- Video playback: up to 12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 10 Watt, 5.35 V, 2 A
Connections & Expansion
- Micro-USB 2.0 , Micro-HDMI , Headphone/microphone combo jack , Dock , USB 2.0 (on keyboard dock)
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
- Black, white
- Integrated Options
- Dockable
- Volume control
- Included Accessories
- Power adapter
- ACPI 5.0
- Localization
- 630 g
- Dimensions (WxDxH) / Weight Details
- 26.2 cm x 18 cm x 1.095 cm / 630 g - tablet , 26.2 cm x 18 cm x 2.285 cm / 1.2 kg - tablet with keyboard
