With its brilliant Acer Snap Hinge 2, this trendy and compact 2-in-1 laptop transforms into four different devices, simply and incredibly smoothly. Add to that its long battery life, and you have a partner for serious work and play - the perfect blend of a laptop's productivity and a tablet's multimedia fun.
Versatile shape-shifter
This device lets you snap the keyboard part on or off with a simple push or pull. Switch effortlessly between four very useful modes - notebook, tablet, tent, and display. -
Eye-catching trendsetter
The Aspire Switch 10 E works perfectly with its dynamic shape and elegant textile-pattern texturing to create one great-looking device. -
Friend of your eyes
You can switch on Acer BluelightShield to reduce stress-causing blue light when you need to look at the screen for long periods. -
Great entertainer
The WXGA screen features IPS technology, so you get clear images when viewing from any angle. The screen is also made of ultra-tough Gorilla Glass, which protects against scratches and also makes scratches less visible. Dual speakers deliver serious sound and work with dual cameras to ensure great video calls.
- Acer Aspire Switch 10 E SW3-016-18L6 - 10.1" - Atom x5 Z8300 - 2 GB RAM - 32 GB eMMC
- Product Type
- Tablet - with keyboard dock
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Atom x5 Z8300 / 1.44 GHz (1.84 GHz) / 2 MB Cache
- Memory
- 2 GB LPDDR3 (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 10.1" LED backlight touchscreen 1280 x 800 / WXGA
- Graphics
- Intel HD Graphics
- Input Device
- Touchpad, detachable keyboard
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0
- Battery
- 2-cell - up to 12 hours
- Dockable
- Black, blue
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Dimensions (WxDxH) - tablet
- 26.2 cm x 18 cm x 1.095 cm
- 630 g
- Localisation
- Region: United Kingdom
- Product Type
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 1.84 GHz
- Number of Cores
- Quad-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 2 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
Storage
- Main Storage
- 32 GB eMMC
Display
- 10.1" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1280 x 800 (WXGA)
- Widescreen
- Image Aspect Ratio
- 16:10
- Image Brightness
- 350 cd/m²
- Glare, CineCrystal
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1600 x 1200 (rear), 1600 x 1200 (front)
- Resolution
- 2 Megapixel (rear), 2 Megapixel (front)
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, microphone
- High Definition Audio
Input
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Technology
- 2-cell lithium polymer
- Capacity
- 30 Wh
- Run Time
- Up to 12 hours
- Battery Run Time
- Video playback: up to 12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 10 Watt, 5.35 V, 2 A
Connections & Expansion
- Micro-USB 2.0 , Micro-HDMI , Headphone/microphone combo jack , Dock , USB 2.0 (on keyboard dock)
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
- Black, blue
- Dockable
- Volume control, Acer BluelightShield technology
- Included Accessories
- Power adapter
- ACPI 5.0
- Localization
- 630 g
- Dimensions (WxDxH) / Weight Details
- 26.2 cm x 18 cm x 1.095 cm / 630 g - tablet , 26.2 cm x 18 cm x 2.285 cm / 1.2 kg - tablet with keyboard
