Acer SW3-016 32GB 10.1" Intel Atom x5-78300 Win 10 Home - Pink
Quicklinx: CC4JWS00 Mfr#: NT.G8YEK.001
  • IEEE 802.11n
  • Bluetooth 4.0
With its brilliant Acer Snap Hinge, this trendy and compact 2-in-1 laptop transforms into four different devices, simply and incredibly smoothly. Add to that its long battery life, and you have a partner for serious work and play - the perfect blend of a laptop's productivity and a tablet's multimedia fun.
  • Switching is a snap
  • Versatile shape-shifter
    This device's perfectly designed Acer Snap Hinge lets you snap the keyboard part on or off with a simple push or pull. Switch effortlessly between four very useful modes: notebook, tablet, tent, and display.
  • Powerful producer
    An Intel quad-core processor gives ample power for serious work and fun, and long battery life lets you compute on the go throughout the day.
  • Data protector
    Acer SwitchLock lets you lock this keyboard dock's HDD so it only works with the tablet part. Use the tablet as the HDD's key - simply snap the tablet off the keyboard to lock the HDD. All your HDD data is now protected and can't be stolen. Simply snap the tablet back on to unlock all that data.
  • Friend of your eyes
    This device features Acer VisionCare, so you can switch on Acer BluelightShield to reduce stress-causing blue light when you need to look at the screen for long periods. Acer LumiFlex auto-boosts contrast when you use this device in direct sunlight - no more squinting when you step outside.
  • Great entertainer
    The HD screen features IPS technology, so you get clear images when viewing from any angle. The screen is also made of ultra-tough Gorilla Glass, which protects against scratches and also makes scratches less visible. Dual speakers deliver serious sound and work with dual cameras to ensure great video calls.
Acer Aspire Switch 10 E SW3-016-12FN - 10.1" - Atom x5 Z8300 - 2 GB RAM - 32 GB eMMC
Tablet - with keyboard dock
Operating System
Win 10 Home 64-bit
Intel Atom x5 Z8300 / 1.44 GHz (1.84 GHz) / 2 MB Cache
2 GB LPDDR3 (provided memory is soldered)
Storage
32 GB eMMC
Display
10.1" LED backlight touchscreen 1280 x 800 / WXGA
Graphics
Intel HD Graphics
Input Device
Touchpad, detachable keyboard
Integrated Webcam
802.11b/g/n, Bluetooth 4.0
2-cell - up to 12 hours
Dockable
Black, pink
Dimensions (WxDxH) - tablet
26.2 cm x 18 cm x 1.095 cm
630 g
Region: United Kingdom
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
1.84 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
Intel Burst Technology
RAM
2 GB (provided memory is soldered)
LPDDR3 SDRAM
Storage
Main Storage
32 GB eMMC
Display
10.1" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1280 x 800 (WXGA)
Widescreen
Image Aspect Ratio
16:10
Image Brightness
350 cd/m²
Glare, CineCrystal
Audio & Video
Graphics Processor
Intel HD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1600 x 1200 (rear), 1600 x 1200 (front)
Resolution
2 Megapixel (rear), 2 Megapixel (front)
Camera Features
720p HD movie recording
Sound
Stereo speakers, microphone
High Definition Audio
Input
Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
Wireless
Wireless Controller
M.2 Card
2-cell lithium polymer
30 Wh
Run Time
Up to 12 hours
Battery Run Time
Video playback: up to 12 hours
AC Adapter
Input
Output
10 Watt, 5.35 V, 2 A
Connections & Expansion
Micro-USB 2.0 , Micro-HDMI , Headphone/microphone combo jack , Dock , USB 2.0 (on keyboard dock)
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Black, pink
Dockable
Volume control, Acer BluelightShield technology
Power adapter
ACPI 5.0
Localization
630 g
Dimensions (WxDxH) / Weight Details
26.2 cm x 18 cm x 1.095 cm / 630 g - tablet , 26.2 cm x 18 cm x 2.285 cm / 1.2 kg - tablet with keyboard
