Acer SA270 27" 1920x1080 4ms VGA DVI HDMI IPS LED Monitor
Quicklinx: CXFGWS00 Mfr#: UM.HS0EE.001
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: None
Interfaces: DVI, HDMI, VGA (HD-15)
£140.26 ex VAT
£168.31 inc VAT
Introducing the fashionable Acer SA0 series, where the elegantly thin design ensures that the monitor looks great and gives more space to its screen. Thinness is in vogue and at just 6.6mm the SA0 is ultra-fashionable. The stylish base, with its pattern of concentric circles, looks great wherever it’s placed. The content on the screen looks fantastic too - with clearer, sharper images in full high-definition color. IPS technology ensures you can share what’s on your screen with friends and family as colors stay true no matter what angle you’re viewing from. In addition, Acer Vision Care incorporates several technologies to reduce eye strain and provide a more comfortable viewing experience.
Acer SA270 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
30 kWh
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
62.1 cm x 21.18 cm x 45.37 cm
3.54 kg
MPR II
Display Type
Energy Class
Class A+
30 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Flicker-Less technology, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology, Ultra Thin
62.1 cm x 21.18 cm x 45.37 cm - with stand
3.54 kg
HDMI , DVI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
MPR II
25 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.4 Watt
Dimensions & Weight Details
With stand - width: 62.1 cm - depth: 21.18 cm - height: 45.37 cm - weight: 3.54 kg , Without stand - width: 62.1 cm - depth: 3.37 cm - height: 37.17 cm - weight: 3.22 kg
Diagonal Size: 27in
Response Time: 4ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 100 - 150
