Product
Acer SA240Y 23.8" 1920x1080 4ms VGA DVI HDMI IPS LED Monitor
Quicklinx: CXFJWS00 Mfr#: UM.QS0EE.001
The elegantly thin design ensures that the monitor looks great and gives more space to its screen. With its wide viewing angles and IPS technology you can share the images with those around you.
Acer SA240Y - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
53.98 cm x 21.18 cm x 40.52 cm
Environmental Standards
ENERGY STAR Qualified
MPR II
2 years warranty
Display Type
Energy Class
Class A
28 kWh
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer EcoDisplay, High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Flicker-Less technology, Acer VisionCare, 6-bit gamma, Wide Viewing Angle, Acer BluelightShield technology, Ultra Thin
53.98 cm x 21.18 cm x 40.52 cm - with stand
HDMI , DVI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
MPR II
24 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.4 Watt
Dimensions & Weight Details
With stand - width: 53.98 cm - depth: 21.18 cm - height: 40.52 cm , Without stand - width: 53.98 cm - depth: 3.41 cm - height: 32.3 cm
ENERGY STAR Certified
