Space saver
The Acer S1 series monitors are built to save you space while looking great. The ultra-thin display and rounded stand radiate a sense of simple modernism. Design accents such as a glossy frame, transparent blue-lit power button, and a porcelain-like stand, all add cutting-edge style, complementing these monitors' elegant looks. -
High performer
You'll enjoy tasks and entertainment more with fine details and smooth movement, thanks to high resolutions, rapid response times and amazing contrast ratios. A host of ports, including HDMI, DVI and VGA, lets you connect other devices - like your notebook or HDTV.
- Acer S271HLFbid - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 50 kWh
- Power Consumption (On mode)
- 34 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- 63.9 cm x 17.4 cm x 44.18 cm
- Environmental Standards
- ENERGY STAR Qualified
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 50 kWh
- Diagonal Size
- 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- HDCP, eColor Management, Acer Adaptive Contrast Management (ACM), matte, ComfyView
- 63.9 cm x 17.4 cm x 44.18 cm - with stand
- VGA , HDMI (HDCP) , DVI
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- 34 W
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - width: 63.9 cm - depth: 3.97 cm - height: 39.39 cm , With stand - width: 63.9 cm - depth: 17.4 cm - height: 44.18 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years - carry-in
