Acer S271HLFbid 27" 1920x1080 1ms VGA DVI HDMI Monitor
Quicklinx: CPD3WS00 Mfr#: UM.HS1EE.F01
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 1ms
Interfaces: DVI, HDMI, VGA (HD-15)
£188.74 ex VAT
£226.48 inc VAT
  • Space saver
    The Acer S1 series monitors are built to save you space while looking great. The ultra-thin display and rounded stand radiate a sense of simple modernism. Design accents such as a glossy frame, transparent blue-lit power button, and a porcelain-like stand, all add cutting-edge style, complementing these monitors' elegant looks.
  • High performer
    You'll enjoy tasks and entertainment more with fine details and smooth movement, thanks to high resolutions, rapid response times and amazing contrast ratios. A host of ports, including HDMI, DVI and VGA, lets you connect other devices - like your notebook or HDTV.
Acer S271HLFbid - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
63.9 cm x 17.4 cm x 44.18 cm
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
50 kWh
34 W
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, eColor Management, Acer Adaptive Contrast Management (ACM), matte, ComfyView
63.9 cm x 17.4 cm x 44.18 cm - with stand
VGA , HDMI (HDCP) , DVI
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 63.9 cm - depth: 3.97 cm - height: 39.39 cm , With stand - width: 63.9 cm - depth: 17.4 cm - height: 44.18 cm
ENERGY STAR Certified
Limited warranty - 2 years - carry-in
Acer S271HLFbid 27 Bundle deal on Acer S271HLFbid 27" 1920x1080 1ms VGA DVI HDMI Monitor
£288.50
Diagonal Size: 27in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 150 - 300
