Acer's Education Series projectors portray clear, large images from either a distance, or when positioned conveniently close to the projection screen. This makes them ideal for use in education facilities or any smaller space. Their high resolution makes for clear and detailed big screen images, while color enhancement features deliver vivid hues.
From near or far
The Education series projectors are great for both small rooms and classrooms. Positioning the projector close to the screen lets you easily point out details without casting shadows or being dazzled by the bright projector beam. For larger or more conventional rooms, you'll appreciate their powerful ability to project a bright image from a distance. -
Rich visuals
Education Series projectors deliver WXGA resolution to display 1080p video, enabling them to display fine detail and small print clearly. Bright projector lamps and high contrast ratios produce vivid images, while Acer ColorBoost and Acer ColorSafe technologies deliver improved color performance and fidelity, with impressive results. -
Conveniently flexible
Acer's top-loading design enables quick and easy lamp replacement. The projector also has a wide range of ports that can connect to all sorts of other equipment. There are connections for multiple PCs, and Crestron network system compliance enables remote projection. -
Eco-smart
Education Series projectors have Acer EcoProjection technology and use very low wattage in standby mode, which lowers their power consumption by up to 75%, lengthens lamp lifespan, and reduces noise levels. The projectors not only reduce energy consumption and lamp replacement costs, they also have less environmental impact.
- Acer S1383WHne - DLP projector - portable - 3D
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness
- 3200 lumens
- Contrast Ratio
- 13000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- 210 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL)
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 260 Watt
- 31.4 cm x 22.3 cm x 9.3 cm
- 2.8 kg
- 3-year warranty
- 3D Capable
Projector
- Brightness
- 3200 lumens
- Contrast Ratio
- 13000:1 (dynamic)
- Image Size
- 91.4 cm - 762 cm
- Projection Distance
- 0.4 m - 3.4 m
- Throw Ratio
- 0.52:1
- Digital Zoom Factor
- 2x
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 210 Watt
- Bulb life cycle
- ColorBoost II+ Technology, 16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.8
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x HDMI , 1 x composite video input , 1 x S-video input , 1 x USB , 1 x network , 1 x component video / RGB input
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 260 Watt
- 31.4 cm
- 22.3 cm
- 9.3 cm
- 2.8 kg
- Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- Sound Emission
- 31 dBA
- Sound Emission (Economic Mode)
- 28 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
