Acer S1383WHne DLP WXGA 3D 3200 Lumens Projector
Quicklinx: BCW5WS00 Mfr#: MR.JK211.002
Acer's Education Series projectors portray clear, large images from either a distance, or when positioned conveniently close to the projection screen. This makes them ideal for use in education facilities or any smaller space. Their high resolution makes for clear and detailed big screen images, while color enhancement features deliver vivid hues.
  • From near or far
    The Education series projectors are great for both small rooms and classrooms. Positioning the projector close to the screen lets you easily point out details without casting shadows or being dazzled by the bright projector beam. For larger or more conventional rooms, you'll appreciate their powerful ability to project a bright image from a distance.
  • Rich visuals
    Education Series projectors deliver WXGA resolution to display 1080p video, enabling them to display fine detail and small print clearly. Bright projector lamps and high contrast ratios produce vivid images, while Acer ColorBoost and Acer ColorSafe technologies deliver improved color performance and fidelity, with impressive results.
  • Conveniently flexible
    Acer's top-loading design enables quick and easy lamp replacement. The projector also has a wide range of ports that can connect to all sorts of other equipment. There are connections for multiple PCs, and Crestron network system compliance enables remote projection.
  • Eco-smart
    Education Series projectors have Acer EcoProjection technology and use very low wattage in standby mode, which lowers their power consumption by up to 75%, lengthens lamp lifespan, and reduces noise levels. The projectors not only reduce energy consumption and lamp replacement costs, they also have less environmental impact.
Acer S1383WHne - DLP projector - portable - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Brightness
3200 lumens
Contrast Ratio
13000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
210 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Speakers
Speaker(s) - integrated
AC 120/230 V
260 Watt
31.4 cm x 22.3 cm x 9.3 cm
2.8 kg
3-year warranty
3D Capable
Projector
Brightness
3200 lumens
Contrast Ratio
13000:1 (dynamic)
Image Size
91.4 cm - 762 cm
Projection Distance
0.4 m - 3.4 m
Throw Ratio
0.52:1
Digital Zoom Factor
2x
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
210 Watt
Bulb life cycle
ColorBoost II+ Technology, 16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology
Lens
Focus Type
Manual
Lens Aperture
F/2.8
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x HDMI , 1 x composite video input , 1 x S-video input , 1 x USB , 1 x network , 1 x component video / RGB input
Wireless remote control
1 x VGA cable
Power Source
AC
Nominal Voltage
AC 120/230 V
260 Watt
31.4 cm
22.3 cm
9.3 cm
2.8 kg
Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
Sound Emission
31 dBA
28 dBA
BCW5 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BCW5 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.43
BCW5 C2G 5m Select High Speed HDMI with Ethernet In Stock £21.49
BCW5 C2G 10m Select High Speed HDMI with Ethernet In Stock £41.25
BCW5 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
