The Acer S1283e projector displays image at least 80 inches in 1 m distance and delivers 3D imaging with 144 Hz speed rate and high brightness. With dust shield solution, this projector can prevent dust impact on projectors and extend lifespan of usage.
Dust accumulation inside the projectors may cause shutdown and brightness decay. Acer brings dust shield solution in projector products. The cutting-edge technology protect projectors from damage caused by airborne dust and sand. To adapt different regions or dusty environments, Acer’s dust resistant projectors offer four guards-sealed engine, vertical board, 3D dust filter and lens shield-to secure projectors to enhance performance in the long run.
Main Features
XGA (1024 x 768) resolution.
Acer SmartFormat technology.
3100 Lumens, 13000:1 contrast ratio.
Constant brightness technology.
Acer ColorSafe II technology.
Built-in 10 W speaker.
Acer CloroBoost II+ technology.
Acer dust-shield solution.
Flexible Setup
Short-throw projection.
Acer top-loading lamp design.
From near or far
The Education series projectors are great for both small rooms and classrooms. Positioning the projector close to the screen lets you easily point out details without casting shadows or being dazzled by the bright projector beam. For larger or more conventional rooms, you'll appreciate their powerful ability to project a bright image from a distance. -
Rich visuals
Education series projectors deliver XGA resolution to display video, enabling them to display fine detail and small print clearly. Bright projector lamps and high contrast ratios produce vivid images, while Acer ColorBoost and Acer ColorSafe technologies deliver improved color performance and fidelity, with impressive results. -
Conveniently flexible
Acer's top-loading design enables quick and easy lamp replacement. These projectors also have a wide range of ports that can connect to all sorts of other equipment. -
Eco-smart
Education series projectors have Acer EcoProjection technology and use very low wattage in standby mode, which lowers their power consumption, lengthens lamp lifespan to many hours, and reduces noise levels. These projectors not only reduce energy consumption and lamp replacement costs, they also have less environmental impact.
- Acer S1283e - DLP projector - ultra short-throw - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness
- 3100 lumens
- Contrast Ratio
- 13000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Lens
- Ultra short-throw fixed lens
- Bulb type
- P-VIP 210 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V
- 260 Watt
- 31.4 cm x 22.3 cm x 9.3 cm
- 2.8 kg
- 3-year warranty
- DLP projector
- 3D Capable
Projector
- Brightness
- 3100 lumens
- Brightness (Reduced)
- 2480 lumens
- Contrast Ratio
- 13000:1 (dynamic)
- Image Size
- 81 cm - 762 cm
- Projection Distance
- 0.4 m - 3.8 m
- Throw Ratio
- 0.617:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- P-VIP 210 Watt
- Bulb life cycle
- Eco-Mode technology, wall colour correction, ColorBoost II+ Technology, Instant Pack Technology, DLP 3D Ready, ColorBoost Technology, SmartFormat Technology, 16:9 aspect ratio support, ColorBoost II Technology, EcoProjection Technology, DynamicBlack technology, 24p True Cinema, Ultra Short Throw Technology, Auto Power Off, Acer ColorSafe II Technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.8
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, composite video, S-Video
- Video Modes
Speakers
- Internal
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x USB - 4 pin mini-USB Type B (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x microphone input - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Voltage Required
- AC 120/230 V
- 260 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.4 cm
- 22.3 cm
- 9.3 cm
- 2.8 kg
- Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- Sound Emission
- 31 dB
- Sound Emission (Economic Mode)
- 28 dB
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
