Acer RT280Kbmjdpx 28" 3840x2160 1ms DVI HDMI DP Monitor
Quicklinx: CP83WS00 Mfr#: UM.PR0EE.001
These displays deliver high resolution, for vivid images that look clear from any angle. You also get multiple display connectors to make it easy to connect any video source. RT0 monitors feature very thin panels. Its ZeroFrame design means the bezels around the sides of the screen are also very thin, to minimize visual clutter. The slender screen is perfectly balanced by the sleek T-shaped stand. RT0 displays use Flicker-less technology to reduce eye-strain-causing screen flickering. Blue Light Filter technology lets you filter out strain-causing blue light when you have to work long hours, and Acer ComfyView technology reduces the light reflected off the screen.
  • Quality visuals
  • Slender body, sleek stand
  • Good for your eyes
Acer RT280K - LED monitor - 4K - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
64 kWh
Power Consumption (On mode)
44 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Tilt
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class B
64 kWh
Diagonal Size
28"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
DVI , DisplayPort , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+15
VESA interface support
1 x DVI cable , 1 x DisplayPort cable
MPR II
44 W
Power Consumption (Typical)
41.5 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
ENERGY STAR Certified
