Acer RT240Ybmid 23.8" 1920x1080 4ms VGA DVI HDMI Monitor
Quicklinx: CP86WS00 Mfr#: UM.QR0EE.005
The Acer RT240Y monitor has an ultra-thin enclosure and an elegant T-shaped metal stand, making it ideal for everyday computing in any space. The stylish Zero Frame design maximizes the view and minimizes visual clutter with a bezel so thin you barely notice it, providing a seamless viewing experience for multi-monitor setups. Combining Acer Flicker-Less and Blue Light Filter technologies with adjustable tilt, the monitor is easy on the eyes, providing a comfortable viewing experience.
  • Quality visuals
    These displays deliver 1920x1080 Full HD resolution enhanced by IPS technology, for vivid images that look clear from any angle. You also get multiple display connectors to make it easy to connect any video source.
  • Slender body, sleek stand
    RT0 monitors feature very thin panels. Its "ZeroFrame" design means the bezels around the sides of the screen are also very thin, to minimize visual clutter. The slender screen is perfectly balanced by the sleek T-shaped stand.
  • Good for your eyes
    RT0 displays use Flicker-less tech to reduce eye-strain-causing screen flickering. Blue Light Filter tech lets you filter out strain-causing blue light when you have to work long hours, and Acer ComfyView tech reduces the light reflected off the screen.
  • No screen tearing
    Say "goodbye" to stuttering and tearing. FreeSync and Adaptive-Sync technologies match the refresh rate of your monitor with your graphics card to provide the smoothest gaming experience.
Acer RT240Ybmid - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class D
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Voltage
53.98 cm x 19.62 cm x 40.53 cm
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class D
32 kWh
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Mercury free, Flicker-Less technology, Blue Light Filter technology, 6-bit gamma, 72% NTSC colour gamut
53.98 cm x 19.62 cm x 40.53 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DVI (HDCP) , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
MPR II
Input Voltage
22 W
13 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.4 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 53.98 cm - depth: 19.62 cm - height: 40.53 cm , Without stand - width: 53.98 cm - depth: 3.41 cm - height: 32.3 cm
Sustainability Information
ENERGY STAR Certified
