Product
Acer R271bmid 27" 1920x1080 4ms VGA DVI HDMI Monitor
Quicklinx: CP84WS00 Mfr#: UM.HR1EE.001
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
Select:
£156.97 ex VAT
£188.36 inc VAT
Marketing description is not available.
  • Slim and trim
    R1 displays have ultra-thin enclosure, thinner than many smartphones. In addition, the ZeroFrame design maximizes the view and minimizes visual clutter with a bezel so thin you barely notice it.
  • On display
    You get a great view with R1 displays. You get high resolution enhanced by IPS technology that produces vivid colors and a wide 178 viewing angle. You also get multiple display connectors to make it easy to connect.
  • A comfortable view
    R1 displays are designed to help preserve eye health. Flicker-less design reduces eye strain from screen flicker. A Blue Light Filter reduces the negative effects of excess blue spectrum exposure, and ComfyView reduces screen reflection.
Acer R271 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
62.1 cm x 22.38 cm x 45.38 cm
Environmental Standards
ENERGY STAR Qualified
MPR II
2 years warranty
Display Type
Energy Class
Class A+
38 kWh
26 W
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut, High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Flicker-Less technology, Blue Light Filter technology, 6-bit gamma
62.1 cm x 22.38 cm x 45.38 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI (HDCP) , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
MPR II
AC 100/240 V (50/60 Hz)
26 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.4 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 62.1 cm - depth: 3.37 cm - height: 37.17 cm , With stand - width: 62.1 cm - depth: 22.38 cm - height: 45.38 cm
ENERGY STAR Certified
Acer R271bmid 27 Bundle deal on Acer R271bmid 27" 1920x1080 4ms VGA DVI HDMI Monitor
£256.73
Diagonal Size: 27in
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 150 - 300
