Slim and trim
R1 displays have ultra-thin enclosure, thinner than many smartphones. In addition, the ZeroFrame design maximizes the view and minimizes visual clutter with a bezel so thin you barely notice it. -
On display
You get a great view with R1 displays. You get high resolution enhanced by IPS technology that produces vivid colors and a wide 178 viewing angle. You also get multiple display connectors to make it easy to connect. -
A comfortable view
R1 displays are designed to help preserve eye health. Flicker-less design reduces eye strain from screen flicker. A Blue Light Filter reduces the negative effects of excess blue spectrum exposure, and ComfyView reduces screen reflection.
- Acer R221Q - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class E
- Energy Consumption per Year
- 26 kWh
- Power Consumption (On mode)
- 13.4 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100/240 V
- Black
- 49.78 cm x 22.38 cm x 38.34 cm
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class E
- 26 kWh
- Diagonal Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Acer EcoDisplay, ComfyView, Zero Frame, Flicker-Less technology, Blue Light Filter technology, 72% NTSC colour gamut
- Black
- 49.78 cm x 22.38 cm x 38.34 cm - with stand
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DVI (HDCP) , HDMI , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Cables Included
- 1 x VGA cable
- MPR II
- Input Voltage
- AC 100/240 V
- 13.4 W
- Power Consumption SDR (On mode)
- 13.4 kWh/1000h
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 450 mW
- Power Consumption Sleep
- 400 mW
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - width: 49.78 cm - depth: 3.34 cm - height: 30.16 cm , With stand - width: 49.78 cm - depth: 22.38 cm - height: 38.34 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
