1800R curvature
The sharply curved screen wraps your games around you to provide a more enveloping viewing experience. -
Fluidly smooth
NVIDIA G-SYNC creates smooth gaming experiences by syncing frames rendered by your GPU to the refresh rate of your monitor, eliminating screen tearing and minimizes stuttering. -
200Hz refresh rate
Rapid 200Hz refresh rates speed up the frames per second to deliver ultra-smooth 2D motion. -
4ms response time
Fast 4ms response times render fast-moving action or scene transitions smoothly without blurring or ghosting. -
Eye tracking
Look. Shoot. Kill. Your eyes and your intuition are your greatest weapon. Immerse yourself in the future of gaming. -
WFHD resolution
WFHD (2560 x 1080) resolution lets you enjoy crisper visuals with more details. -
VisionCare technologies
Stay in the fight for hours with VisionCare technologies, including Acer Flicker-less, BlueLightShield, ComfyView and Low-dimming technologies.
- Acer Predator Z271Tbmiphzx - LED monitor - curved - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 48 kWh
- Power Consumption (On mode)
- 33 W
- Curved Screen
- Adaptive-Sync Technology
- NVIDIA G-SYNC
- USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 144 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, DisplayPort
- Height, swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, red
- 61.9 cm x 26.84 cm x 39.91 cm
- 7.6 kg
- MPR II
- Display Type
- Energy Class
- Class B
- 48 kWh
- Diagonal Size
- 27"
- Curved Screen
- Yes (1800R)
- NVIDIA G-SYNC
- Built-in Devices
- USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Ambient light sensor, Flicker-Less technology, DTS Sound, 8-bit gamma, Predator GameView technology, Wide Viewing Angle, Acer BluelightShield technology, Eye Tracking Sensor, 72% NTSC colour gamut
- Black, red
- 61.9 cm x 26.84 cm x 39.91 cm - with stand
- 7.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 7 Watt
- HDMI , DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 60
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Integrated cable management, VESA interface support
- Cables Included
- 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- MPR II
- Input Voltage
- 33 W
- Power Consumption (Typical)
- 27 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.4 Watt
- Dimensions & Weight Details
- With stand - width: 61.9 cm - depth: 26.84 cm - height: 39.91 cm - weight: 7.6 kg , Without stand - width: 61.9 cm - depth: 3.13 cm - height: 37.25 cm - weight: 5.2 kg
