Acer Predator Z271Tbmiphzx 1920x1080 HDMI DP USB Gaming Monitor
Quicklinx: CPBFWS00 Mfr#: UM.HZ1EE.A01
Stay ahead of the curve and bring your gaming experience to the next level.
  • 1800R curvature
    The sharply curved screen wraps your games around you to provide a more enveloping viewing experience.
  • Fluidly smooth
    NVIDIA G-SYNC creates smooth gaming experiences by syncing frames rendered by your GPU to the refresh rate of your monitor, eliminating screen tearing and minimizes stuttering.
  • 200Hz refresh rate
    Rapid 200Hz refresh rates speed up the frames per second to deliver ultra-smooth 2D motion.
  • 4ms response time
    Fast 4ms response times render fast-moving action or scene transitions smoothly without blurring or ghosting.
  • Eye tracking
    Look. Shoot. Kill. Your eyes and your intuition are your greatest weapon. Immerse yourself in the future of gaming.
  • WFHD resolution
    WFHD (2560 x 1080) resolution lets you enjoy crisper visuals with more details.
  • VisionCare technologies
    Stay in the fight for hours with VisionCare technologies, including Acer Flicker-less, BlueLightShield, ComfyView and Low-dimming technologies.
Acer Predator Z271Tbmiphzx - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
48 kWh
Power Consumption (On mode)
33 W
Curved Screen
Adaptive-Sync Technology
NVIDIA G-SYNC
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Voltage
Black, red
61.9 cm x 26.84 cm x 39.91 cm
7.6 kg
MPR II
Display Type
Energy Class
Class B
48 kWh
Diagonal Size
27"
Curved Screen
Yes (1800R)
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% NTSC
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Ambient light sensor, Flicker-Less technology, DTS Sound, 8-bit gamma, Predator GameView technology, Wide Viewing Angle, Acer BluelightShield technology, Eye Tracking Sensor, 72% NTSC colour gamut
Black, red
61.9 cm x 26.84 cm x 39.91 cm - with stand
7.6 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
HDMI , DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
Tilt Angle
-5/+25
Swivel Angle
60
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Integrated cable management, VESA interface support
1 x DisplayPort cable , 1 x SuperSpeed USB cable
MPR II
Input Voltage
33 W
Power Consumption (Typical)
27 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.4 Watt
Dimensions & Weight Details
With stand - width: 61.9 cm - depth: 26.84 cm - height: 39.91 cm - weight: 7.6 kg , Without stand - width: 61.9 cm - depth: 3.13 cm - height: 37.25 cm - weight: 5.2 kg
