Acer Predator XB281HK 28" 3840x2160 1ms HDMI DP USB LED Monitor
Quicklinx: BQSFWS00 Mfr#: UM.PX1EE.001
Diagonal Size: 28in
Max Resolution: 3840 x 2160
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
21 in stock
£523.62 ex VAT
£628.34 inc VAT
Game with no compromise. Super-fast refresh rates come in an aggressive design.
  • Pixel power
    Monitors used to sacrifice color for speed, but now you can warp to a new level of gaming on a stunning display.
  • Smooth
    Experience a whole smooth. NVIDIA G-SYNC eliminates screen tearing and minimizes stuttering for legendary PC gaming.
  • Seize control
    Conquer your enemies with Predator GameView. Shooting aim-points and customizable gaming profiles give you the upper hand.
  • Fast refresh
    Minimize motion blur and zip through space with 144 Hz native refresh rate. Now that's fast.
Predator XB281HK - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class C
Energy Consumption per Year
87 kWh
Power Consumption (On mode)
59 W
Adaptive-Sync Technology
NVIDIA G-SYNC
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
Brightness
300 cd/m²
Response Time
1 ms
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Height, pivot (rotation), tilt
ERP, TCO Displays 6.0
Display Type
Energy Class
Class C
87 kWh
59 W
Diagonal Size
28"
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Response Time
1 ms
Backlight Technology
LED backlight
Audio
Speakers
DisplayPort , USB 3.0 upstream , HDMI , 4 x USB 3.0 downstream
Mechanical
Stand
1 x DisplayPort cable , 1 x SuperSpeed USB cable , 1 x SuperSpeed USB cable
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.45 Watt
On / Off Switch
Acer Predator XB281HK 28 Bundle deal on Acer Predator XB281HK 28" 3840x2160 1ms HDMI DP USB LED Monitor
£622.79
BQSF C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BQSF C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.86
BQSF C2G 5m Select High Speed HDMI with Ethernet In Stock £22.92
BQSF C2G 10m Select High Speed HDMI with Ethernet In Stock £44.00
BQSF C2G 15m Select High Speed HDMI with Ethernet In Stock £59.60
BQSF C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Diagonal Size: 28in
Response Time: 1ms
Interfaces: HDMI
Brand: Acer
Price Range Ex VAT: 500 - 750
