Pixel power
Monitors used to sacrifice color for speed, but now you can warp to a new level of gaming on a stunning display. -
Smooth
Experience a whole smooth. NVIDIA G-SYNC eliminates screen tearing and minimizes stuttering for legendary PC gaming. -
Seize control
Conquer your enemies with Predator GameView. Shooting aim-points and customizable gaming profiles give you the upper hand. -
Fast refresh
Minimize motion blur and zip through space with 144 Hz native refresh rate. Now that's fast.
- Predator XB281HK - LED monitor - 28"
- LED-backlit LCD monitor - 28"
- Energy Class
- Class C
- Energy Consumption per Year
- 87 kWh
- Power Consumption (On mode)
- 59 W
- Adaptive-Sync Technology
- NVIDIA G-SYNC
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
- Brightness
- 300 cd/m²
- Response Time
- 1 ms
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), tilt
- Black
- ERP
- Display Type
- Energy Class
- Class C
- 87 kWh
- 59 W
- Diagonal Size
- 28"
- NVIDIA G-SYNC
- Built-in Devices
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Response Time
- 1 ms
- Backlight Technology
- LED backlight
- Black
Audio
- Speakers
- DisplayPort , USB 3.0 upstream , HDMI , 4 x USB 3.0 downstream
Mechanical
- Included Accessories
- Stand
- Cables Included
- 1 x DisplayPort cable , 1 x SuperSpeed USB cable , 1 x SuperSpeed USB cable
- ERP
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.45 Watt
- On / Off Switch
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£622.79
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 0.5m Select High Speed HDMI with Ethernet | In Stock | £6.31 |
C2G 5m Select High Speed HDMI with Ethernet | In Stock | £21.05 |
C2G 10m Select High Speed HDMI with Ethernet | In Stock | £40.43 |
C2G 15m Select High Speed HDMI with Ethernet | In Stock | £54.75 |
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black | In Stock | £14.57 |
