Acer Predator XB272bmiprz 27" 1920x1080 HDMI DP USB Gaming Monito
Quicklinx: CPBXWS00 Mfr#: UM.HX2EE.005
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
38 in stock
£541.67 ex VAT
£650.00 inc VAT
  • Furiously fast refresh
    Don't skip a single frame. Ever. With a fast refresh rate, you better buckle up or get blown away.
  • Seize control
    Conquer your enemies with Predator GameView. Shooting aim-points and customizable gaming profiles give you the upper hand.
  • Break through borders
    See more of what matters - the game. ZeroFrame bezels feed you more screen.
Acer Predator XB272 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Adaptive-Sync Technology
NVIDIA G-SYNC
Stereo speakers, USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 240 Hz
Brightness
400 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Black, dark silver
61.4 cm x 26.8 cm x 52.4 cm
7.51 kg
Display Type
Energy Class
Class A
44 kWh
Diagonal Size
27"
NVIDIA G-SYNC
Built-in Devices
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
400 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
ErgoStand, 72% NTSC colour gamut, Zero Frame, Mercury free, Acer VisionCare, Predator GameView technology
Black, dark silver
61.4 cm x 26.8 cm x 52.4 cm - with stand
7.51 kg
Audio
Speakers - stereo
DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , HDMI , Audio line-out
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
115 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x SuperSpeed USB cable
AC 120/230 V
30 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.47 Watt
Dimensions & Weight Details
With stand - width: 61.4 cm - depth: 26.8 cm - height: 52.4 cm - weight: 7.51 kg , Without stand - width: 61.4 cm - depth: 6.1 cm - height: 36.7 cm - weight: 5.63 kg
Acer Predator XB272bmiprz 27 Bundle deal on Acer Predator XB272bmiprz 27" 1920x1080 HDMI DP USB Gaming Monito
£640.84
Diagonal Size: 27in
Response Time: 1ms
Interfaces: HDMI
Brand: Acer
Price Range Ex VAT: 500 - 750
