Acer Predator XB271HUAbmiprz 27" 2560x1440 HDMI DP USB Gaming Mon
Quicklinx: CPBLWS00 Mfr#: UM.HX1EE.A01
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£456.93 ex VAT
£548.31 inc VAT
XB1 monitors are packed full of features to choose from. Create your own ultimate gaming experience with extreme resolutions, fast refresh rates, IPS technology and more. Standard features like GameView and NVIDIA G-SYNC make every choice a good one.
  • Pixel power
    Gaming monitors used to sacrifice color for speed, but now there's no need to compromise with gorgeous and powerful displays. IPS technology provides rich color and you can even overclock to 165 Hz of gaming glory. Once you try it, you won't go back.
  • NVIDIA G-SYNC
    Get the smooth gaming experience with NVIDIA G-SYNC. G-SYNC eliminates screen tearing and minimizes stuttering by syncing the refresh rate of your monitor with the frames, rendered by your GPU. This is legendary PC gaming.
  • Seize control
    Take charge of any situation with Predator GameView. Adjust dark boost levels, make precise color adjustments and set up aim points for hip-fire accuracy. Save custom settings in three profiles you can switch between at any time.
  • NVIDIA ULMB
    Tired of that ugly motion blur, when you drift around corners? Get a superb racing experience with NVIDIA ULMB (Ultra Low Motion Blur) technology for crystal clear gameplay at high frame rates.
  • All the colors
    Good color brings game worlds to life and lets you pick out enemies with precision. Acer managed to get the XB1 up to sRGB. Now that's some accurate color!
  • Get comfortable
    Predator EyeProtect's Flicker-less, Blue-light Filter, ComfyView and Low-dimming technologies minimize eye-strain from long gaming sessions.
  • ZeroFrame
    One for fun, two for multitasking, three for an ultimate gaming experience. Enjoy immersive multiple-monitor setups with ZeroFrame bezels, that keep you in the game.
Predator XB271HUA - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
65 kWh
Power Consumption (On mode)
45 W
Adaptive-Sync Technology
NVIDIA G-SYNC
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 144 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
61.4 cm x 24.5 cm x 40.1 cm
8 kg
Display Type
Energy Class
Class C
65 kWh
45 W
Diagonal Size
27"
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
100000000:1
Colour Support
Response Time
1 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
100% sRGB colour gamut, Zero Frame, NVIDIA Ultra Low Motion Blur Technology, Flicker-Less technology, Low Dimming technology, Predator GameView technology
8 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , USB 3.0 upstream , HDMI , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
60
Height Adjustment
150 mm
Aluminum enclosure, integrated cable management, Acer Eyeprotect technology
Stand
1 x DisplayPort cable , 1 x SuperSpeed USB cable
Power Consumption Stand by
470 mW
Power Consumption (Off Mode)
430 mW
Acer Predator XB271HUAbmiprz 27 Bundle deal on Acer Predator XB271HUAbmiprz 27" 2560x1440 HDMI DP USB Gaming Mon
£556.10
Diagonal Size: 27in
Response Time: 1ms
Interfaces: HDMI
Brand: Acer
Price Range Ex VAT: 300 - 500
