Acer Predator XB271Hbmiprz 27" 1920x1080 HDMI DP USB Gaming Monit
Quicklinx: CPBQWS00 Mfr#: UM.HX1EE.011
Monitors used to sacrifice color for speed, but now you can warp to an amazing level of gaming on a stunning display. Conquer your enemies with Predator GameView. Shooting aim-points and customizable gaming profiles give you the upper hand. Minimize motion blur and zip through space with high native refresh rate. Now that's fast.
  • Pixel power
  • Seize control
  • Fast refresh
Predator XB271H - LED monitor - Full HD (1080p) - 27"
Display Type
Energy Class
Class B
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34 W
Diagonal Size
27"
Adaptive-Sync Technology
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Brightness
300 cd/m²
Colour Support
16.7 million colours
Response Time
1 ms
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ComfyView, 100% sRGB colour gamut, Zero Frame, NVIDIA Ultra Low Motion Blur Technology, Flicker-Less technology, Low Dimming technology, Blue Light Filter technology, Predator GameView technology, Predator EyeProtect
64 cm x 26.8 cm x 56.5 cm - with stand
7.7 kg
Audio
Speakers
DisplayPort , USB 3.0 upstream , HDMI , 4 x USB 3.0 downstream
Mechanical
Display Position Adjustments
Tilt Angle
-5/+35
Swivel Angle
30
Height Adjustment
150 mm
Aluminum enclosure
1 x DisplayPort cable , 1 x SuperSpeed USB cable
Slovenia
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.45 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 64 cm - depth: 6.2 cm - height: 35.7 cm - weight: 5.3 kg , With stand - width: 64 cm - depth: 26.8 cm - height: 56.5 cm - weight: 7.7 kg
Environmental Standards
ENERGY STAR Certified
