Monitors used to sacrifice color for speed, but now you can warp to an amazing level of gaming on a stunning display. Conquer your enemies with Predator GameView. Shooting aim-points and customizable gaming profiles give you the upper hand. Minimize motion blur and zip through space with high native refresh rate. Now that's fast.
Pixel power
Monitors used to sacrifice color for speed, but now you can warp to an amazing level of gaming on a stunning display. -
Seize control
Conquer your enemies with Predator GameView. Shooting aim-points and customizable gaming profiles give you the upper hand. -
Fast refresh
- Acer Predator XB271H - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 50 kWh
- Power Consumption (On mode)
- 34 W
- Adaptive-Sync Technology
- NVIDIA G-SYNC
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 144 Hz
- Brightness
- 300 cd/m²
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Black
- 64 cm x 26.8 cm x 56.5 cm
- 7.7 kg
- Localisation
- Slovenia
- Environmental Standards
- ENERGY STAR Qualified
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 50 kWh
- Diagonal Size
- 27"
- NVIDIA G-SYNC
- Built-in Devices
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- 1 ms
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- ComfyView, Zero Frame, NVIDIA Ultra Low Motion Blur Technology, Flicker-Less technology, Low Dimming technology, Blue Light Filter technology, Predator GameView technology, Predator EyeProtect
- Black
- 64 cm x 26.8 cm x 56.5 cm - with stand
- 7.7 kg
Audio
- Speakers
- DisplayPort , USB 3.0 upstream , HDMI , 4 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 30
- Height Adjustment
- 150 mm
- Aluminum enclosure
- Cables Included
- 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- Localisation
- Slovenia
- 34 W
- Power Consumption Stand by
- 0.5 Watt
- 0.45 Watt
- On / Off Switch
- Dimensions & Weight Details
- Without stand - width: 64 cm - depth: 6.2 cm - height: 35.7 cm - weight: 5.3 kg , With stand - width: 64 cm - depth: 26.8 cm - height: 56.5 cm - weight: 7.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
