Product
Acer Predator XB241YUbmiprz 23.8" 2560x1440 HDMI DP USB Gaming Mo
Quicklinx: CPBSWS00 Mfr#: UM.QX1EE.001
Diagonal Size: 23.8in
Max Resolution: 2560 x 1440
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£502.63 ex VAT
£603.15 inc VAT
A rapid refresh rate and blazingly-fast response time deliver ultra-smooth motion scenes. Let the lower latency and immersive graphics of these monitors vastly improve your gaming experience.
  • Eye protection
    These monitors help to reduce eye strain with low-dimming, and anti-glare technologies. Acer ComfyView technology cuts screen glare to further reduce eye strain.
  • Ergonomic setup
    The Acer ErgoStand lets the XB series monitors pivot, tilt, swivel, and move up or down, so you can find the most comfortable angle from where to oversee your push into enemy territory.
Acer Predator XB241YU - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class B
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Brightness
350 cd/m²
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
54.1 cm x 25.9 cm x 53 cm
6.6 kg
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class B
44 kWh
30 W
Diagonal Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Brightness
350 cd/m²
Colour Support
Screen Coating
Anti-glare
Backlight Technology
LED backlight
54.1 cm x 25.9 cm x 53 cm - with stand
6.6 kg
Audio
Speakers
DisplayPort , HDMI , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+35
Swivel Angle
30
Height Adjustment
150 mm
1 x DisplayPort cable , 1 x SuperSpeed USB cable
MPR II
27 Watt
Power Consumption Stand by
0.42 Watt
Power Consumption (Off Mode)
0.35 Watt
Dimensions & Weight Details
With stand - width: 54.1 cm - depth: 25.9 cm - height: 53 cm - weight: 6.6 kg , Without stand - width: 54.1 cm - depth: 6.35 cm - height: 37.85 cm
ENERGY STAR Certified
Acer Predator XB241YUbmiprz 23.8 Bundle deal on Acer Predator XB241YUbmiprz 23.8" 2560x1440 HDMI DP USB Gaming Mo
£599.62
Response Time: 1ms
Interfaces: HDMI
Brand: Acer
Price Range Ex VAT: 500 - 750
