Acer Predator XB241H 24" 1920x1080 HDMI Display Port IPS
Quicklinx: C26ZWS00 Mfr#: UM.FX1EE.001
The world's first curved gaming monitor that completely immerses you in the game universe. Absolutely stunning.
  • Predator XB1
    Game with no compromise. Super-fast refresh rates and IPS 1 color come in an aggressive new design.
  • Pixel Power
    Monitors used to sacrifice color for speed, but now you can warp to a new level of gaming on a stunning IPS display.
  • New Smooth
    Experience a whole new smooth. NVIDIA G-SYNC TM eliminates screen tearing and minimizes stuttering for legendary PC gaming
  • Eye-tracking
    Look. Shoot. Kill. Your eyes and your intuition are your greatest weapon. Immerse yourself in the future of gaming.
  • Seize Control
    Conquer your enemies with Predator GameView. Shooting aim-points and customizable gaming profiles give you the upper hand.
  • Fast Refresh
    Minimize motion blur and zip through space with 144Hz native refresh rate. Now that's fast.
Acer Predator XB241H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
36 W
Adaptive-Sync Technology
NVIDIA G-SYNC
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 180 Hz
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
56.7 cm x 26.8 cm x 54.2 cm
6.31 kg
Environmental Standards
ENERGY STAR Qualified
MPR II, TUV, VCCI, DDC-2B, NOM, CCC, FCC, DDC/CI, ISO 9241-307, WEEE, cTUVus, EAC, TUV Rheinland
Display Type
Energy Class
Class C
52 kWh
Diagonal Size
24"
NVIDIA G-SYNC
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
100% sRGB
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
24 - 180 kHz
Horizontal Refresh Rate
30 - 212 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Aluminum enclosure, ComfyView, Zero Frame, NVIDIA Ultra Low Motion Blur Technology, Flicker-Less technology, Low Dimming technology, Blue Light Filter technology, Predator GameView technology
56.7 cm x 26.8 cm x 54.2 cm - with stand
6.31 kg
Audio
Speakers
Output Power / Channel
2 Watt
DisplayPort , HDMI
Mechanical
Tilt Angle
-5/+35
Swivel Angle
30
Height Adjustment
150 mm
Volume control, integrated cable management, VESA interface support, Acer Eyeprotect technology
1 x DisplayPort cable - DisplayPort to DisplayPort
Input Voltage
36 W
Power Consumption (Typical)
28 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.45 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 56.7 cm - depth: 26.8 cm - height: 54.2 cm - weight: 6.31 kg , Without stand - width: 56.6 cm - depth: 6.1 cm - height: 33.5 cm - weight: 3.93 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
10 - 85%
