The 34-inch curved 21:9 ultra-wide Predator X34 monitor (formally known as the XR341CKA) is a curved monitor with NVIDIA G-SYNC, providing an immersive gaming experience with minimal stutters and screen tears. It features DTS sound, 2x7W speakers, a zero-frame design with a futuristic aluminum base and ambient lighting options create an exciting entertainment experience with style. The Predator X34's UltraWide QHD (3440 x 1440) IPS panel has a 178-degree viewing angle, and also features flicker-less technology to lessen eye fatigue for a more comfortable gaming or working experience.
Curved immersion
Get immersed in the world's greatest curved gaming display. Your gaming experience will never be the same again. -
Super-smooth
Get the buttery-smooth gameplay you've dreamed of. NVIDIA G-SYNC eliminates screen tearing and minimises stuttering for legendary PC gaming. -
Become a hunter
Conquer your enemies with Predator GameView. Shooting aim-points and customizable gaming profiles give you the upper hand. -
Overclock
Boost your refresh rate up to 100Hz with built-in overclocking. Minimise motion blur and enjoy more frames per second.
- Acer Predator X34 - LED monitor - curved - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class C
- Energy Consumption per Year
- 93 kWh
- Curved Screen
- Adaptive-Sync Technology
- NVIDIA G-SYNC, VESA Adaptive-Sync
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- QHD 3440 x 1440 at 75 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, DisplayPort
- Height, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- Localisation
- EMEA
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Display Type
- Energy Class
- Class C
- 93 kWh
- Diagonal Size
- 34"
- Curved Screen
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- 4 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Picture in picture, ambient light sensor, picture by picture, Acer Adaptive Contrast Management (ACM), ultra wide viewing angle, Zero Frame, Flicker-Less technology, 6-axis colour adjustment, Blue Light Filter technology, DTS Sound
- Black
Audio
- Speakers - stereo
- Output Power / Channel
- 7 Watt
- DisplayPort , HDMI , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
- Height, tilt
- Tilt Angle
- -5/+35
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Charging via USB, VESA interface support, Acer Eyeprotect technology, Acer ColorPlus technology
- Included Accessories
- Stand
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- Localisation
- EMEA
- Input Voltage
- Limited warranty - 2 years
