Epic gaming? How about MONUMENTAL!
Acer's new Predator Z650 gaming projector is a short-throw marvel that projects a huge screen image for a truly immersive gaming experience.
Multiple image enhancement features make for an even more clear and engaging game environment. Optional accessories take you even further with curved screen projection and wireless HD connections. Combine all that with epic audio capabilities and the Z650 takes you there.
Short-Throw projection allows 100" images with just 1.5m. Games modes x 3 with ColorPurity brings fierce clarity. 20W DTS Sound & Bluetooth audio connection. WirelessHD* for wireless gaming with no compromise to quality.
Watch the Projector in action:
Custom splash screen
With the Z650, you can be greeted by a favorite gaming moment every time you boot up the device. With a few simple button presses, the Predator Z650 can do a screen capture and save it as a custom splash screen. -
Glorious gaming
Game Automode improves visibility, contrast and color using real-time analysis. -
Play anywhere
Game wherever you want with short-throw projection and wireless streaming at lossless 1080p. -
DTS Sound
With DTS Sound and two 10W stereo speakers built in, you're free to take the Z650 anywhere without bringing a sound system. Enjoy explosions, screeching tires and more without hassles. -
Bluetooth audio
Stream audio to a Bluetooth headset or speaker system for a wireless audio experience. -
Portable audio
Entertain your crowd with built-in dual DTS Sound speakers that make some serious noise. -
Pure color
ColorPurity produces an expanded gamut so you'll see games as the developer intended.
- Acer Predator Z650 - DLP projector - 3D - black, red
- DLP projector - 1080p
- 3D Capable
- Black, red
- Built-in Devices
- Stereo speakers
- Brightness
- 2200 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 240 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 424 Watt
- 35.7 cm x 24.1 cm x 9.8 cm
- 3.4 kg
- 3D Capable
- Built-in Devices
- Stereo speakers
- Enclosure Colour
- Black, red
Projector
- Brightness
- 2200 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 137 cm - 762 cm
- Projection Distance
- 0.9 m - 4.6 m
- Throw Ratio
- 0.69 - 0.76:1
- Digital Zoom Factor
- 2x
- Resolution
- Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 240 Watt
- Bulb life cycle
- sRGB colour profile, Acer ColorSafe II Technology, ColorBoost 3D Technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.6 - 2.78
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video, MHL
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- Speakers
- 2 x right / left channel
- 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - mini-DIN , 1 x component video input - RCA x 3 , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin mini-USB Type B , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x composite video input - RCA , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB - 4 pin USB Type A
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 424 Watt
- 35.7 cm
- 24.1 cm
- 9.8 cm
- 3.4 kg
- 0 °C
- 40 °C
- Sound Emission
- 33 dBA
- Sound Emission (Economic Mode)
- 30 dBA
