Acer Predator Gaming 1080p Short Throw Projector
Quicklinx: BZY0WS00 Mfr#: MR.JMS11.002
Epic gaming? How about MONUMENTAL!
Acer's new Predator Z650 gaming projector is a short-throw marvel that projects a huge screen image for a truly immersive gaming experience.
Multiple image enhancement features make for an even more clear and engaging game environment. Optional accessories take you even further with curved screen projection and wireless HD connections. Combine all that with epic audio capabilities and the Z650 takes you there.
Short-Throw projection allows 100" images with just 1.5m. Games modes x 3 with ColorPurity brings fierce clarity. 20W DTS Sound & Bluetooth audio connection. WirelessHD* for wireless gaming with no compromise to quality.
Watch the Projector in action:
  • Custom splash screen
    With the Z650, you can be greeted by a favorite gaming moment every time you boot up the device. With a few simple button presses, the Predator Z650 can do a screen capture and save it as a custom splash screen.
  • Glorious gaming
    Game Automode improves visibility, contrast and color using real-time analysis.
  • Play anywhere
    Game wherever you want with short-throw projection and wireless streaming at lossless 1080p.
  • DTS Sound
    With DTS Sound and two 10W stereo speakers built in, you're free to take the Z650 anywhere without bringing a sound system. Enjoy explosions, screeching tires and more without hassles.
  • Bluetooth audio
    Stream audio to a Bluetooth headset or speaker system for a wireless audio experience.
  • Portable audio
    Entertain your crowd with built-in dual DTS Sound speakers that make some serious noise.
  • Pure color
    ColorPurity produces an expanded gamut so you'll see games as the developer intended.
Acer Predator Z650 - DLP projector - 3D - black, red
DLP projector - 1080p
3D Capable
Black, red
Built-in Devices
Stereo speakers
Brightness
2200 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
UHP 240 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video
Speakers
Speaker(s) - integrated
AC 120/230 V
424 Watt
35.7 cm x 24.1 cm x 9.8 cm
3.4 kg
3D Capable
Built-in Devices
Stereo speakers
Enclosure Colour
Black, red
Projector
Brightness
2200 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
137 cm - 762 cm
Projection Distance
0.9 m - 4.6 m
Throw Ratio
0.69 - 0.76:1
Digital Zoom Factor
2x
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 240 Watt
Bulb life cycle
sRGB colour profile, Acer ColorSafe II Technology, ColorBoost 3D Technology
Lens
Focus Type
Manual
Lens Aperture
F/2.6 - 2.78
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video, MHL
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - mini-DIN , 1 x component video input - RCA x 3 , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin mini-USB Type B , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x composite video input - RCA , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB - 4 pin USB Type A
Power Source
AC
AC 120/230 V
424 Watt
35.7 cm
24.1 cm
9.8 cm
3.4 kg
Sound Emission
33 dBA
30 dBA
