Brand
Acer PM161Qbu 15.6" 1920x1080 7ms USB-C/Micro USB IPS LED Monitor
Quicklinx: G0JSWS00 Mfr#: UM.ZP1EE.005
Diagonal Size: 15.6in
Max Resolution: 1920 x 1080
Response Time: 7ms
Speakers: None
Interfaces: USB-C
£145.23 ex VAT
£174.27 inc VAT
Vibrant Images
Crisp, true-to-life colors come alive in Full HD 1080p resolution. Movies and games appear more real and dramatic, and small details and text are clear with 1920x1080 resolution in a 16:9 aspect ratio.
Portable and Versatile
Get outstanding portability with an ultra-light, ultraslim PM1 series monitor. At just 790g (with stand detached) and a mere 2cm thin, the 15.6" display slides easily into bags and can accompany you everywhere. It’s ideal for use on the go, takes up minimal desk space, and is perfect for use as a secondary monitor during presentations.
Smooth and blur free: With a 60 Hz refresh rate and 7 ms response time, even high-speed action scenes will look crisp and smooth
  • Portable and versatile
    Get outstanding portability with an ultra-light, ultra-slim PM1 series monitor. At just 0.97 kg and only 2 cm thin, the 15.6" display slides easily into bags and can accompany you everywhere. It's ideal for use on the go, takes up minimal desk space, and is perfect for use as a secondary monitor during presentations.
  • Vibrant images
  • Single-cable simplicity
    Declutter your life and keep things simple with this single-cable solution. One USB-C cable hooks up your PM1 display to a laptop, sharing your display and transferring data while also supplying power. With this super-handy cable, you can also connect to your smartphone or tablet.
  • Wide viewing angle
    Share what's on your screen with family and friends as colors stay true at wide viewing angles of up to 170° thanks to IPS panel technology.
Acer PM161Q bu - LED monitor - Full HD (1080p) - 15.6"
LED-backlit LCD monitor - 15.6"
Energy Class
Class C
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.17925 mm
Brightness
220 cd/m²
Contrast Ratio
800:1 / 100000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
262,000 colours
Colour Gamut
45% NTSC
Input Connectors
USB-C
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
37.7 cm x 2 cm x 23.47 cm
970 g
Display Type
Energy Class
Class C
Diagonal Size
15.6"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.17925 mm
Brightness
220 cd/m²
Contrast Ratio
Colour Support
262,000 colours
Colour Gamut
45% NTSC
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
58 - 62 Hz
Horizontal Refresh Rate
30 - 70 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
170
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Ultra Slim Design, 6-bit gamma, Wide Viewing Angle
37.7 cm x 2 cm x 23.47 cm - with stand
970 g
USB-C
Mechanical
Tilt
Tilt Angle
+15/+35
1 x USB-C cable , 1 x micro-USB cable
Input Voltage
7 kWh/1000h
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
With stand - width: 37.7 cm - depth: 2 cm - height: 23.47 cm - weight: 970 g , Without stand - width: 37.7 cm - depth: 2 cm - height: 23.47 cm - weight: 790 g
20 - 80%
Response Time: 7ms
Speakers: None
Interfaces: USB-C
Brand: Acer
