With projection this crisp and bright, even your most complex concepts will be grasped easily by associates, clients or students. The high resolution and brilliant color of Acer’s Large-Venue Series projectors will let the power of your ideas shine through, and their top-notch technologies will keep you in complete control.
- Acer P6600 - DLP projector - 3D - LAN
- DLP projector - 1080p
- 3D Capable
- Built-in Devices
- Stereo speakers
- Brightness
- 5000 lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 365 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4500 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 460 Watt
- 36.9 cm x 29.4 cm x 11.6 cm
- 4.5 kg
- 3-year warranty
- 3D Capable
- Built-in Devices
- Stereo speakers
Projector
- Brightness
- 5000 lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 53 cm - 762 cm
- Projection Distance
- 1 m - 9.1 m
- Throw Ratio
- 1.41 - 2.24:1
- Digital Zoom Factor
- 2x
- Resolution
- Full HD - WUXGA (1920 x 1200)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 365 Watt
- Bulb life cycle
- 16:9 aspect ratio support, 4:3 aspect ratio support
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.5-3.26
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- Speakers
- 2 x right / left channel
- 1 x composite video input - RCA , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x component video input - RCA x 3 , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 2 x audio line-in - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (male) (management) , 1 x USB - 4 pin mini-USB Type B , 1 x USB - 4 pin USB Type A , 2 x network - RJ-45
- Included Accessories
- Carrying case, dust cover, wireless remote control
- Power Source
- AC
- Voltage Required
- 460 Watt
- 36.9 cm
- 29.4 cm
- 11.6 cm
- 4.5 kg
- Limited warranty - 3 years , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- Sound Emission
- 35 dB
- Sound Emission (Economic Mode)
- 30 dB
