Acer P6200 XGA 5000 Lumens DLP Projector
Installation required? Contact us today!
Quicklinx: DHD8WS00 Mfr#: MR.JMF11.001
Portability: Non-portable
Hurry, only 2 left in stock!
£829.34 ex VAT
£995.20 inc VAT
With projection this crisp and bright, even your complex concepts will be grasped easily by associates, clients or students. The high resolution and brilliant color of Acer's Large-Venue series projectors will let the power of your ideas shine through, and their advanced technologies will keep you in complete control.
  • Compelling visuals
    Even in bright rooms, your presentations will shine as brilliantly as your ideas. After prolonged projector use, colors and text will still be vibrant and crisp, thanks to Acer's advanced color technologies. Achieve perfect projection with keystone correction. You can also engage your audience more by projecting in 3D.
  • Smart savings
    Acer EcoProjection technology greatly increases lamp lifetime and decreases power use by going into standby mode when the projector is idle.
Acer P6200 - DLP projector - 3D - LAN
DLP projector
3D Capable
Built-in Devices
Stereo speakers
United Kingdom, Europe
Brightness
5000 lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
UHP 310 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4500 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video LAN
Speakers
Speaker(s) - integrated
AC 120/230 V
383 Watt
36.9 cm x 29.4 cm x 11.6 cm
4.5 kg
DLP projector
3D Capable
Built-in Devices
Stereo speakers
Projector
Brightness
5000 lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
43 cm - 762 cm
Projection Distance
1 m - 11.4 m
Throw Ratio
1.86 - 2.95:1
Digital Zoom Factor
2x
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 310 Watt
Bulb life cycle
16:9 aspect ratio support
Lens
Focus Type
Manual
Lens Aperture
F/2.5-3.23
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x component video input - RCA x 3 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 3 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - 4 pin mini-USB Type B , 1 x network - RJ-45
Carrying case, lens cover, wireless remote control
1 x component video cable , 1 x composite video cable , 1 x VGA cable
Power Source
AC
Nominal Voltage
AC 120/230 V
383 Watt
36.9 cm
29.4 cm
11.6 cm
4.5 kg
Sound Emission
33 dB
28 dB
Brand: Acer
Price Range Ex VAT: 750 - 1000
