High brightness provides the ability to project crystal clear, vibrant images from a long distance on a large screen even in daytime indoors. Dynamic Black improves image contrast by analyzing onscreen content frame-by-frame and then dynamically adjusting lamp power to optimize black levels. The black can be extremely black and white is brilliant white. Project in either light or dark environments with Acer LumiSense+ which adjusts the image based on available light. Equipped with an intelligent ambient light sensor, projector can optimize image brightness and color saturation based on ambient lighting conditions. What's even better, content-aware process also analyzes projected contents frame by frame and dynamically adjusts image visibility to the optimum level. Acer ColorBoost3D presents true-to-life colors through an optimized 6-segment color-wheel design, advanced lamp illumination technology, and powerful TI image processing. It can reduce brightness decay and color shift while displaying 2D and 3D content through enhancing color brightness, while also compensating color saturation and color temperature.
ColorSafe II technology combines the dynamic RGB control techniques, and advanced projector lamps to extend projector lifespan. The technology prevents yellow hues, the sign of color decay, so even after thousands of hours of usage, projector continues to deliver consistent, natural colors. Image distortion sometimes happens when the projector is placed with improper distance or in a wrong position. Finding the right angle for your presentation will come easier with keystone correction which corrects vertical & horizontal distortions. Built-in speakers provide powerful sound, eliminating the need for external speakers. The audio ensures movies come to life, songs have more depth, and games are more engaging.
Bright, clear images
High brightness provides the ability to project crystal clear, vibrant images from a long distance on a large screen even in daytime indoors. -
Expressive levels of Dynamic Black Contrast
Dynamic Black improves image contrast by analyzing onscreen content frame-by-frame and then dynamically adjusting lamp power to optimize black levels. The black can be extremely black and white is brilliant white. -
Acer LumiSense+ ambient light detection
Project in either light or dark environments with Acer LumiSense+ which adjusts the image based on available light. Equipped with an intelligent ambient light sensor, projector can optimize image brightness and color saturation based on ambient lighting conditions. What's even better, content-aware process also analyzes projected contents frame by frame and dynamically adjusts image visibility to the optimum level. -
Give color a boost with ColorBoost3D
Acer ColorBoost3D presents true-to-life colors through an optimized 6-segment color-wheel design, advanced lamp illumination technology, and powerful TI image processing. It can reduce brightness decay and color shift while displaying 2D and 3D content through enhancing color brightness, while also compensating color saturation and color temperature. -
Immune to color decay with Acer ColorSafe II
ColorSafe II technology combines the dynamic RGB control techniques, and advanced projector lamps to extend projector lifespan. The technology prevents yellow hues, the sign of color decay, so even after thousands of hours of usage, projector continues to deliver consistent, natural colors. -
Horizontal & vertical keystone correction
Image distortion sometimes happens when the projector is placed with improper distance or in a wrong position. Finding the right angle for your presentation will come easier with keystone correction which corrects vertical & horizontal distortions. -
Turn up the volume with speaker
- Acer P5630 - DLP projector - portable - 3D - LAN
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 4000 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 240 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 15000 hour(s) - economic mode
- Video Input
- (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G), LAN
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 290 Watt
- 31.5 cm x 21.4 cm x 10.3 cm
- 2.73 kg
- 3D Capable
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 4000 ANSI lumens
- Brightness (Reduced)
- 3200 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 81 cm - 762 cm
- Projection Distance
- 1 m - 7.3 m
- Throw Ratio
- 1.13 - 1.47:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- WUXGA - WUXGA (1920 x 1200) (native) / 1920 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 240 Watt
- Bulb life cycle
- Instant Pack Technology, DLP 3D Ready, Auto Vertical Keystone, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Auto Power Off, Acer ColorSafe II Technology, Quick-Start, ColorBoost 3D Technology, Acer LumiSense+
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.5-2.78
- Zoom Type
- Manual
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -20 / +20
- Horizontal Keystone Correction
- -20 / +20
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Video Interfaces
- VGA, HDMI, composite video, MHL
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x composite video input - RCA
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Power Source
- AC
- Nominal Voltage
- AC 120/230 V
- 290 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.5 cm
- 21.4 cm
- 10.3 cm
- 2.73 kg
- 0 °C
- 40 °C
- 80%
- Sound Emission
- 31 dBA
- Sound Emission (Economic Mode)
- 24 dBA
