Acer P5515 projector features high brightness and contrast ratio for showcasing vividly detailed text and images. DLP 3D ready and HDMI 3D capability make work presentations more convincing, and home entertainment more exciting.
1080p Full HD resolution and wide format sharpen your vision
Full HD offers exquisite display and 16:9 aspect ratio delivering wide format for more content. -
DynamicBlack technology
DynamicBlack technology dramatically improves image contrast by using dynamic lamp power adjustment to analyze content frame by frame. Acer projectors feature this technology for vivid image quality and a high contrast ratio. -
Acer ColorBoost 3D technology
Acer projectors present nature's true colors with Acer ColorBoost 3D technology for both 2D and 3D content. ColorBoost 3D has the ability to reduce brightness decay and color shift when displaying content through enhancing color brightness. At the same time, it compensates color saturation and color temperature. -
Acer ColorSafe II technology
Acer projectors featuring ColorSafe II technology use dynamic RGB gain control to secure color fidelity, even after prolonged use. -
Split screen for multitasking
Acer eDisplay Pro allows a maximum of four users to display their contents on screen at the same time, which is mighty powerful especially for business meeting or education. Picture that you're in a meeting, and four of your colleagues can simultaneously display four different reports from four devices to one screen. How convenient! -
Built-in speaker
With a built-in speaker, Acer P5515 projector allows you to enjoy studio nuance and enhanced clearer sound without external speaker. No matter in meeting room or classroom, these projectors' sound effect satisfies audiences all the time. -
4-corner correction
4-corner correction enables user to adjust distortion from any single corners. Even the projector is not placed in a proper position, the function makes correction process easy and time-saving. -
Auto ceiling mount correction
When the projector is installed in the ceiling, auto ceiling mount correction can detect the projector position and automatically adjust the orientation of the image.
- Acer P5515 - DLP projector - portable - 3D
- DLP projector - 1080p
- 3D Capable
- Microdisplay
- DarkChip 3
- Brightness
- 4000 ANSI lumens
- Contrast Ratio
- 12000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 260 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
- Video Input
- RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 325 Watt
- 31.4 cm x 22.3 cm x 9.3 cm
- 2.5 kg
- 3-year warranty
- 3D Capable
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 4000 ANSI lumens
- Brightness (Reduced)
- 3200 ANSI lumens
- Contrast Ratio
- 12000:1 (dynamic)
- Image Size
- 79 cm - 762 cm
- Projection Distance
- 1 m - 7.1 m
- Throw Ratio
- 1.07 - 1.45:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 260 Watt
- Bulb life cycle
- BrilliantColor, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, ColorBoost 3D Technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.5-2.93
- Zoom Type
- Manual
- Zoom Factor
- 1.36x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, MHL
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- Speakers
- 2 x right / left channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x serial RS-232 (management) , 1 x network - RJ-45 , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 325 Watt
- 31.4 cm
- 22.3 cm
- 9.3 cm
- 2.5 kg
- Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- Sound Emission
- 34 dBA
- Sound Emission (Economic Mode)
- 29 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
