Acer P5330W WXGA 4500 Lumens DLP Projector
Quicklinx: DHDHWS00 Mfr#: MR.JPJ11.002
Portability: Portable
£525.06 ex VAT
£630.07 inc VAT
High brightness provides the ability to project crystal clear, vibrant images from a long distance on a large screen even in daytime indoors. DynamicBlack improves image contrast by analyzing onscreen content frame-by-frame and then dynamically adjusting lamp power to optimize black levels. The black can be extremely black and white is brilliant white. Project in either light or dark environments with Acer LumiSense+ which adjusts the image based on available light. Equipped with an intelligent ambient light sensor, projector can optimize image brightness and color saturation based on ambient lighting conditions. What's even better, content-aware process also analyzes projected contents frame by frame and dynamically adjusts image visibility to the optimum level.
Acer ColorBoost3D presents true-to-life colors through an optimized 6-segment color-wheel design, advanced lamp illumination technology, and powerful TI image processing. It can reduce brightness decay and color shift while displaying 2D and 3D content through enhancing color brightness, while also compensating color saturation and color temperature. ColorSafe II technology combines the dynamic RGB control techniques, and advanced projector lamps to extend projector lifespan. The technology prevents yellow hues, the sign of color decay, so even after thousands of hours of usage, projector continues to deliver consistent, natural colors.
Image distortion sometimes happens when the projector is placed with improper distance or in a wrong position. Finding the right angle for your presentation will come easier with keystone correction which corrects vertical & horizontal distortions. Adjust distortion from any single corners. Even the projector is not placed in a proper position, the function makes correction process easy and time-saving. Built in speakers provide powerful sound, eliminating the need for external speakers. The audio ensures movies come to life, songs have more depth, and games are more engaging.
  • Bright, clear images
  • Expressive levels of dynamic black contrast
  • Acer LumiSense+ ambient light detection
  • Give color a boost with ColorBoost3D
  • Immune to color decay with Acer ColorSafe II
  • Horizontal & vertical keystone correction
  • Four corner correction
  • Turn up the volume with speaker
Acer P5330W - DLP projector - portable - 3D - LAN
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
4500 lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
UHP 240 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 15000 hour(s) - economic mode
Video Input
RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G), LAN
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V
290 Watt
31.5 cm x 21.4 cm x 10.3 cm
2.73 kg
3D Capable
Built-in Devices
Speaker
Ethernet
Projector
Brightness
4500 lumens
Brightness (Reduced)
3600 lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
1 m - 7.7 m
Throw Ratio
1.19 - 1.54:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 240 Watt
Bulb life cycle
Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Auto Power Off, Acer ColorSafe II Technology, Quick-Start, ColorBoost 3D Technology, Acer LumiSense+
Lens
Focus Type
Manual
Lens Aperture
F/2.5-2.78
Zoom Type
Manual
Zoom Factor
1.3x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-20 / +20
Horizontal Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x composite video input - RCA
Security Features
Power Source
AC
Nominal Voltage
AC 120/230 V
290 Watt
Power Consumption Stand by
0.5 Watt
31.5 cm
21.4 cm
10.3 cm
2.73 kg
80%
Sound Emission
31 dBA
24 dBA
Brand: Acer
Price Range Ex VAT: 500 - 750
