Acer P5327W DLP WXGA 3D 4000 Lumens Projector
Quicklinx: BCVQWS00 Mfr#: MR.JLR11.002
Brightness: 4000ANSI lumens, 4000ANSI lumens
Portability: Portable
Hurry, only 2 left in stock!
£506.83 ex VAT
£608.19 inc VAT
The Acer P5327W projector with it's crisp and bright visuals, even your most complex concepts will be grasped easily by associates, clients or students. 4000 Lumens brightness and enhanced colour will let the power of your ideas shine through. Integrated with multiple IO interfaces, it is compatible with all kinds of industrial standard devices. Top-notch technologies -HV keystone and four corner correction enables easy setup. To top it off, Acer P5 projector is ideal for banquet halls or large conference rooms.
Acer ColorSafe II
  • Color fidelity is maintained dynamically, keeping colors true and stable over time.
4 Corner Correction
  • Correct horizontal and vertical distortion (caused by non-perpendicular screen alignment) without moving projector.
Auto Ceiling Mount Correction
  • This feature automatically flips the projected image over if the projector is turned upside down.
EcoProjection
  • Helps the planet by saving energy, by not using hazardous substances, and by using recycled materials.
Wireless Projection
  • Project content without bothersome cables. Say goodbye to cable clutter and manual connecting of devices.
Acer P5327W - DLP projector - portable - 3D
DLP projector - 720p
3D Capable
Built-in Devices
Stereo speakers
Microdisplay
DarkChip 3
Brightness
4000 lumens
Contrast Ratio
17000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
UHP 250 Watt
Bulb life cycle
Up to 2500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V
385 Watt
30.8 cm x 21.1 cm x 8.6 cm
2.4 kg
3D Capable
Built-in Devices
Stereo speakers
Projector
Microdisplay
DarkChip 3
Brightness
4000 lumens
Brightness (Reduced)
3200 lumens
Contrast Ratio
17000:1 (dynamic)
Image Size
75 cm - 762 cm
Projection Distance
1 m - 7.8 m
Throw Ratio
1.21 - 1.57:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
WXGA - WXGA (1280 x 800) (native) / 1900 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 250 Watt
Bulb life cycle
BrilliantColor, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 16:10 aspect ratio support, 4:3 aspect ratio support, Acer ColorSafe II Technology, ColorBoost 3D Technology
Lens
Focus Type
Manual
Lens Aperture
F/2.59-2.87
Zoom Type
Manual
Zoom Factor
1.3x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Video Modes
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x network - RJ-45 , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B (management) , 1 x serial RS-232 (management) , 1 x USB - 4 pin USB Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Carrying case, wireless remote control
1 x VGA cable
Security Features
Power Source
AC
Nominal Voltage
AC 120/230 V
385 Watt
Power Consumption Stand by
0.5 Watt
30.8 cm
21.1 cm
8.6 cm
2.4 kg
Sound Emission
32 dBA
27 dBA
BCVQ C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BCVQ C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.34
BCVQ C2G 5m Select High Speed HDMI with Ethernet In Stock £21.17
BCVQ C2G 10m Select High Speed HDMI with Ethernet In Stock £40.63
BCVQ C2G 15m Select High Speed HDMI with Ethernet In Stock £55.03
BCVQ C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Brand: Acer
Price Range Ex VAT: 500 - 750
