Acer P1623 DLP 3D WUXGA 3500LM HDMI 3D Projector
Quicklinx: CPZWWS00 Mfr#: MR.JNC11.002
Acer P1623 - DLP projector - portable - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DarkChip 3
Brightness
3500 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
UHP 220 Watt
Bulb life cycle
Up to 3500 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - internal
AC 120/230 V
273 Watt
30.8 cm x 21.1 cm x 8.6 cm
2.3 kg
3D Capable
Projector
Microdisplay
DarkChip 3
Brightness
3500 ANSI lumens
Brightness (Reduced)
2800 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
117 cm - 762 cm
Projection Distance
1.5 m - 7.4 m
Throw Ratio
1.15 - 1.5:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 220 Watt
Bulb life cycle
Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, MHL compliance, ColorBoost 3D Technology
Lens
Focus Type
Manual
Lens Aperture
F/2.59-2.87
Zoom Type
Manual
Zoom Factor
1.3x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Video Modes
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x Mobile High-Definition Link (MHL) / HDMI , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B (management) , 1 x USB (power only) - 4 pin USB Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 (management)
Carrying case, wireless remote control
1 x VGA cable
FCC, ROSTEST
Power Source
AC
AC 120/230 V
273 Watt
Power Consumption Stand by
0.5 Watt
30.8 cm
21.1 cm
8.6 cm
2.3 kg
Sound Emission
31 dBA
26 dBA
