Acer P1525 DLP 1080p 4000LM HDMI 3D Projector
Quicklinx: CPZXWS00 Mfr#: MR.JMP11.002
Acer Essential series projectors are best value projectors ideal for everyday use, at work or home. Make your presentations more compelling and entertainment more exciting with high brightness, high contrast and DLP® 3D Ready2, while adhering to your bottom line.
Acer P1525 - DLP projector - portable - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
4000 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
UHP 250 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - internal
AC 120/230 V
370 Watt
30.8 cm x 21.1 cm x 8.6 cm
2.5 kg
3-year warranty
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
4000 ANSI lumens
Brightness (Reduced)
3200 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
75 cm - 762 cm
Projection Distance
1 m - 7.6 m
Throw Ratio
1.15 - 1.5:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 250 Watt
Bulb life cycle
BrilliantColor, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, Quick-Start, ColorBoost 3D Technology, ExtremECO, Acer LumiSense+
Lens
Focus Type
Manual
Lens Aperture
F/2.59-2.87
Zoom Type
Manual
Zoom Factor
1.3x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Video Modes
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x serial RS-232 (management) , 1 x S-video input - 4 pin mini-DIN , 1 x USB - 4 pin USB Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Carrying case, wireless remote control
Power Source
AC
AC 120/230 V
370 Watt
Power Consumption Stand by
0.5 Watt
30.8 cm
21.1 cm
8.6 cm
2.5 kg
Limited warranty - 3 years
Sound Emission
32 dBA
27 dBA
