Acer Essential series projectors are best value projectors ideal for everyday use, at work or home. Make your presentations more compelling and entertainment more exciting with high brightness, high contrast and DLP® 3D Ready2, while adhering to your bottom line.
- Acer P1525 - DLP projector - portable - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 4000 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 250 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V
- 370 Watt
- 30.8 cm x 21.1 cm x 8.6 cm
- 2.5 kg
- 3-year warranty
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 4000 ANSI lumens
- Brightness (Reduced)
- 3200 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 75 cm - 762 cm
- Projection Distance
- 1 m - 7.6 m
- Throw Ratio
- 1.15 - 1.5:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 250 Watt
- Bulb life cycle
- BrilliantColor, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, Quick-Start, ColorBoost 3D Technology, ExtremECO, Acer LumiSense+
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.59-2.87
- Zoom Type
- Manual
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
Speakers
- Internal
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x serial RS-232 (management) , 1 x S-video input - 4 pin mini-DIN , 1 x USB - 4 pin USB Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- Included Accessories
- Carrying case, wireless remote control
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 370 Watt
- Power Consumption Stand by
- 0.5 Watt
- 30.8 cm
- 21.1 cm
- 8.6 cm
- 2.5 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- Sound Emission
- 32 dBA
- Sound Emission (Economic Mode)
- 27 dBA
