Acer P1385WB projector is ideal for everyday use, at work or home. It makes your presentations more compelling and entertainment more exciting with 3200 ANSI lumens high brightness, high contrast and HDMI 3D capability. Furthermore, with multimedia function, it enables photos, audio and video playback directly from USB drives.
- Acer P1385WB - DLP projector - portable - 3D - LAN
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Microdisplay
- DarkChip 3
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 200 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (SECAM, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G), LAN
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 256 Watt
- 30.8 cm x 21.1 cm x 8.6 cm
- 2.3 kg
- 3-year warranty
- 3D Capable
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3200 ANSI lumens
- Brightness (Reduced)
- 2560 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 71 cm - 762 cm
- Projection Distance
- 1 m - 9.7 m
- Throw Ratio
- 1.5 - 1.65:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 200 Watt
- Bulb life cycle
- Instant Pack Technology, DLP 3D Ready, Auto Vertical Keystone, SmartFormat Technology, EcoProjection Technology, 24p True Cinema, Acer ColorSafe II Technology, MHL compliance, ColorBoost 3D Technology
Lens
- Lens Aperture
- F/2.56-2.8
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- SECAM, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x Mobile High-Definition Link (MHL) / HDMI , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input , 2 x USB - 4 pin USB Type A , 1 x USB - 4 pin mini-USB Type B , 1 x serial RS-232 (management) , 1 x VGA output , 1 x network - RJ-45 , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 256 Watt
- Power Consumption Sleep
- 0.5 Watt
- 30.8 cm
- 21.1 cm
- 8.6 cm
- 2.3 kg
- Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- Sound Emission
- 26 dBA
- Sound Emission (Economic Mode)
- 30 dBA
