Acer P1385WB TCO DLP WXGA 3D 3200 Lumens Projector
Quicklinx: BCVWWS00 Mfr#: MR.JLQ11.002
Acer P1385WB projector is ideal for everyday use, at work or home. It makes your presentations more compelling and entertainment more exciting with 3200 ANSI lumens high brightness, high contrast and HDMI 3D capability. Furthermore, with multimedia function, it enables photos, audio and video playback directly from USB drives.
Acer P1385WB - DLP projector - portable - 3D - LAN
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DarkChip 3
Brightness
3200 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
UHP 200 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (SECAM, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G), LAN
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V
256 Watt
30.8 cm x 21.1 cm x 8.6 cm
2.3 kg
3-year warranty
3D Capable
Projector
Microdisplay
DarkChip 3
Brightness
3200 ANSI lumens
Brightness (Reduced)
2560 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
71 cm - 762 cm
Projection Distance
1 m - 9.7 m
Throw Ratio
1.5 - 1.65:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 200 Watt
Bulb life cycle
Instant Pack Technology, DLP 3D Ready, Auto Vertical Keystone, SmartFormat Technology, EcoProjection Technology, 24p True Cinema, Acer ColorSafe II Technology, MHL compliance, ColorBoost 3D Technology
Lens
Lens Aperture
F/2.56-2.8
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x Mobile High-Definition Link (MHL) / HDMI , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input , 2 x USB - 4 pin USB Type A , 1 x USB - 4 pin mini-USB Type B , 1 x serial RS-232 (management) , 1 x VGA output , 1 x network - RJ-45 , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm
Carrying case, wireless remote control
1 x VGA cable
Power Source
AC
Nominal Voltage
AC 120/230 V
256 Watt
Power Consumption Sleep
0.5 Watt
30.8 cm
21.1 cm
8.6 cm
2.3 kg
Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
Sound Emission
26 dBA
30 dBA
BCVW C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BCVW C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.31
BCVW C2G 5m Select High Speed HDMI with Ethernet In Stock £21.06
BCVW C2G 15m Select High Speed HDMI with Ethernet In Stock £54.75
BCVW C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
