Acer Essential series projectors are best value projectors ideal for everyday use, at work or home. Make your presentations more compelling and entertainment more exciting with high brightness, high contrast and DLP 3D Ready, while adhering to your bottom line.
Main Features
Acer P1385W DLP 3D Projector.
20000:1 Contrast Ratio.
3200 Lumens.
1280 x 800 Resolution
Clear and dynamic
WXGA resolution, high brightness and contrast, Acer Color technology: your presentations will be more engaging thanks to sharper text and dynamic images, even from a distance. With DLP 3D Ready technology, you can also enjoy an immersive 3D entertainment experience, just like at the movies. -
Acer Dust Shield
If dust accumulates, a projector may not work properly and lose brightness. Thanks to Acer Dust Shield technology, Essential projectors are protected against dust. As a result, they operate more efficiently and for longer, while requiring less maintenance. -
Practical and flexible
Essential projectors feature intuitive functionality, including 9-button control panels on the top of the unit, and a 40° keystone correction system that automatically adjusts for vertical distortion. Their ceiling-mounting system offers four types of installation, so you can choose the one best suited to your needs. -
Environmentally-friendly
Essential projectors feature environmentally-friendly technologies. Power consumption can be reduced by 90% in standby mode, and by 70% when switched on. This extends lamp life (up to 10,000 hours) and reduces replacement costs.
- Acer P1385W - DLP projector - portable - 3D
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Microdisplay
- DarkChip 3
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 200 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (SECAM, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 252 Watt
- 30.8 cm x 21.1 cm x 8.6 cm
- 2 kg
- 3-year warranty
- 3D Capable
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3200 ANSI lumens
- Brightness (Reduced)
- 2560 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 71 cm - 762 cm
- Projection Distance
- 1 m - 9.7 m
- Throw Ratio
- 1.5 - 1.65:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 200 Watt
- Bulb life cycle
- Instant Pack Technology, DLP 3D Ready, Auto Vertical Keystone, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 24p True Cinema, 16:10 aspect ratio support, 4:3 aspect ratio support, Acer ColorSafe II Technology, MHL compliance, ColorBoost 3D Technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.56-2.8
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- SECAM, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x Mobile High-Definition Link (MHL) / HDMI , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin mini-USB Type B , 1 x serial RS-232 (management) , 1 x VGA output , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), PIN code
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 252 Watt
- Power Consumption Stand by
- 0.5 Watt
- 30.8 cm
- 21.1 cm
- 8.6 cm
- 2 kg
- Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- Sound Emission
- 26 dBA
- Sound Emission (Economic Mode)
- 30 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
