Acer P1287 DLP XGA 4200 Lumens Projector
Quicklinx: BCVVWS00 Mfr#: MR.JL411.002
Brightness: 4200ANSI lumens
Portability: Portable
£499.89 ex VAT
£599.86 inc VAT
Acer Essential series projectors are the optimal projectors ideal for everyday use, at work or home. Make your presentations more compelling and entertainment more exciting with high brightness, high contrast and DLP 3D ready, while adhering to your bottom line.
Acer P1287 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Brightness
4200 lumens
Contrast Ratio
17000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC)
31.4 cm x 22.3 cm x 9.3 cm
2.5 kg
DLP projector
3D Capable
Projector
Brightness
4200 lumens
Brightness (Reduced)
3360 lumens
Contrast Ratio
17000:1
Image Size
127 cm - 762 cm
Projection Distance
1.6 m - 9.7 m
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
120 Hz
Bulb life cycle
Instant Pack Technology, DLP 3D Ready, Auto Vertical Keystone, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, MHL compliance, ColorBoost 3D Technology
Lens
Focus Type
Manual
Lens Aperture
F/2.41-2.7
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - mini-DIN , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 2 x audio line-in - mini-phone 3.5 mm
31.4 cm
22.3 cm
9.3 cm
2.5 kg
Sound Emission
34 dBA
29 dBA
BCVV C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BCVV C2G 5m Select High Speed HDMI with Ethernet In Stock £20.51
BCVV C2G 15m Select High Speed HDMI with Ethernet In Stock £53.35
Brand: Acer
Price Range Ex VAT: 300 - 500
