With high resolution, high brightness, high contrast and Acer color technology, your presentations will be more compelling with sharper texts and vibrant images, even from a distance. Combined with DLP 3D ready you can also enjoy an immersive theater-like 3D entertainment experience.
Acer Dust Shield
The accumulation of dust over time can cause a projector to not function properly and lose its original brightness. With Acer Dust Shield, this projector can defend against the detrimental effects of dust, allowing it to work better, for longer, and requiring less maintenance. -
Convenient and flexible
The projector has features, that make it easy to use, including 9-key control panel on the top of the projector and 40-degree keystone correction, that automatically adjusts vertical distortions. Its ceiling mounts provide four ways to install them, so you can pick the method that optimally suits your needs. -
Eco-smart
The projector sports eco-friendly technologies, that are better for the planet and good for your wallet. Its standby power consumption can be reduced, when powered on, which helps to prolong the lifespan of its lamps for lower replacement costs.
- Acer P1286 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Microdisplay
- DarkChip 3
- Brightness
- 3400 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- P-VIP 195 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V
- 250 Watt
- 31.5 cm x 21.4 cm x 9.8 cm
- 2.4 kg
- DLP projector
- 3D Capable
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3400 ANSI lumens
- Brightness (Reduced)
- 2720 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 69 cm - 762 cm
- Projection Distance
- 1.2 m - 11.8 m
- Throw Ratio
- 1.94 - 2.16:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- P-VIP 195 Watt
- Bulb life cycle
- Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, Acer ColorSafe II Technology, MHL compliance, ColorBoost 3D Technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.41-2.53
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, MHL
- Video Modes
Speakers
- Internal
- Sound Output Mode
- Mono
- Output Power / Channel
- 3 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB (power only) - 4 pin USB Type A , 1 x serial RS-232 (management)
- Included Accessories
- Wireless remote control
- FCC, ROSTEST
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 250 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.5 cm
- 21.4 cm
- 9.8 cm
- 2.4 kg
- 0 °C
- 40 °C
- Sound Emission
- 31 dBA
- Sound Emission (Economic Mode)
- 28 dBA
