Acer P1286 DLP XGA 3400LM HDMI 3D Projector
Quicklinx: CQ00WS00 Mfr#: MR.JMW11.002
With high resolution, high brightness, high contrast and Acer color technology, your presentations will be more compelling with sharper texts and vibrant images, even from a distance. Combined with DLP 3D ready you can also enjoy an immersive theater-like 3D entertainment experience.
  • Acer Dust Shield
    The accumulation of dust over time can cause a projector to not function properly and lose its original brightness. With Acer Dust Shield, this projector can defend against the detrimental effects of dust, allowing it to work better, for longer, and requiring less maintenance.
  • Convenient and flexible
    The projector has features, that make it easy to use, including 9-key control panel on the top of the projector and 40-degree keystone correction, that automatically adjusts vertical distortions. Its ceiling mounts provide four ways to install them, so you can pick the method that optimally suits your needs.
  • Eco-smart
    The projector sports eco-friendly technologies, that are better for the planet and good for your wallet. Its standby power consumption can be reduced, when powered on, which helps to prolong the lifespan of its lamps for lower replacement costs.
Acer P1286 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DarkChip 3
Brightness
3400 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
P-VIP 195 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - internal
AC 120/230 V
250 Watt
31.5 cm x 21.4 cm x 9.8 cm
2.4 kg
DLP projector
3D Capable
Projector
Microdisplay
DarkChip 3
Brightness
3400 ANSI lumens
Brightness (Reduced)
2720 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
69 cm - 762 cm
Projection Distance
1.2 m - 11.8 m
Throw Ratio
1.94 - 2.16:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
P-VIP 195 Watt
Bulb life cycle
Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, Acer ColorSafe II Technology, MHL compliance, ColorBoost 3D Technology
Lens
Focus Type
Manual
Lens Aperture
F/2.41-2.53
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
Video Modes
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
3 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB (power only) - 4 pin USB Type A , 1 x serial RS-232 (management)
Wireless remote control
FCC, ROSTEST
Power Source
AC
AC 120/230 V
250 Watt
Power Consumption Stand by
0.5 Watt
31.5 cm
21.4 cm
9.8 cm
2.4 kg
Sound Emission
31 dBA
28 dBA
