Acer Essential series projectors are best value projectors ideal for everyday use, at work or home. Make your presentations more compelling and entertainment more exciting with high brightness, high contrast and DLP 3D Ready, while adhering to your bottom line.
Bright and Vivid
With WXGA resolution, high brightness, high contrast and Acer Color Technology, your presentations will be more compelling with sharper texts and vibrant images, even from a distance. Combined with DLP 3D Ready you can also enjoy an immersive theater-like 3D entertainment experience. -
Acer Dust Shield
The accumulation of dust over time can cause a projector to not function properly and lose its original brightness. With Acer Dust Shield, Essential series projectors can defend against the detrimental effects of dust, allowing them to work better, for longer, and requiring less maintenance. -
Convenient and flexible
Essential series projectors have features that make them easy to use including 9 key control panels on the top of the projectors and 40-degree keystone correction that automatically adjusts vertical distortions. Their ceiling mounts provide four ways to install them so you can pick the method that best suits your needs. -
Eco-smart
Essential series projectors sport eco-friendly technologies that are better for the planet and good for your wallet. Their standby power consumption can be reduced by 90% and by 70% when powered on, which helps to prolong the lifespan of its lamps (Up to 10,000 hours) for lower replacement costs.
- Acer P1285B - DLP projector - portable - 3D - LAN
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 3200 lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 200 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G), LAN
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V
- 256 Watt
- 30.8 cm x 21.1 cm x 8.6 cm
- 2.3 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3200 lumens
- Brightness (Reduced)
- 2560 lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 61 cm - 762 cm
- Projection Distance
- 1 m - 11.3 m
- Throw Ratio
- 1.86 - 2.04:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 200 Watt
- Bulb life cycle
- BrilliantColor, Instant Pack Technology, Auto Vertical Keystone, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, Acer ColorSafe II Technology, ColorBoost 3D Technology, ExtremECO
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.56-2.8
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Internal
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin mini-USB Type B , 1 x serial RS-232 (management) , 2 x Mobile High-Definition Link (MHL) / HDMI , 2 x USB - 4 pin USB Type A , 1 x network - RJ-45
- Included Accessories
- Wireless remote control
- FCC, ROSTEST
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 256 Watt
- Power Consumption Stand by
- 0.5 Watt
- 30.8 cm
- 21.1 cm
- 8.6 cm
- 2.3 kg
- 0 °C
- 40 °C
- Sound Emission
- 30 dBA
- Sound Emission (Economic Mode)
- 26 dBA
