- Acer P1285 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 200 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V (50/60 Hz)
- 254 Watt
- 30.8 cm x 21.1 cm x 8.6 cm
- 2.3 kg
- DLP projector
- 3D Capable
Projector
- Brightness
- 3200 ANSI lumens
- Brightness (Reduced)
- 2560 ANSI lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 61 cm - 762 cm
- Projection Distance
- 1 m - 11.3 m
- Throw Ratio
- 1.86 - 2.04:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 200 Watt
- Bulb life cycle
- Instant Pack Technology, DLP 3D Ready, Auto Vertical Keystone, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, Acer ColorSafe II Technology, ColorBoost 3D Technology, ExtremECO
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.56-2.8
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
Speakers
- Internal
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin mini-USB Type B , 1 x serial RS-232 (management) , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x USB - 4 pin USB Type A
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Voltage Required
- 254 Watt
- 30.8 cm
- 21.1 cm
- 8.6 cm
- 2.3 kg
- 0 °C
- 40 °C
- Sound Emission
- 30 dBA
- Sound Emission (Economic Mode)
- 26 dBA
