With projection this crisp and bright, even your most complex concepts will be easily grasped by associates, clients or students. The power of your ideas will shine through with the high resolution and brilliant colour of Professional and Education Series projectors, while top-notch technologies keep you in complete control.
Main Features
XGA (1024 x 768)
20,000:1
4:3 (Native), 16:9 (Compatible)
4000 Hour (Normal Mode); 6000 Hour (Economy Mode)
3200 lm
- Acer P1285 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness
- 3300 lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video
- Speakers
- Speaker(s) - internal
- 30.8 cm x 21.1 cm x 8.6 cm
- 2 kg
- 3-year warranty
- DLP projector
- 3D Capable
Projector
- Brightness
- 3300 lumens
- Brightness (Reduced)
- 2560 lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 132 cm - 254 cm
- Projection Distance
- 2 m - 3.78 m
- Throw Ratio
- 1.86 - 2.04:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Bulb type
- 190 Watt
- Bulb life cycle
- DLP 3D Ready, Auto Vertical Keystone, SmartFormat Technology, EcoProjection Technology, Acer ColorSafe II Technology, ColorBoost 3D Technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.56-2.8
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
Speakers
- Internal
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin mini-USB Type B , 1 x serial RS-232 (management) , 2 x Mobile High-Definition Link (MHL) / HDMI
- Included Accessories
- Carrying case, remote control
- Cables Included
- 1 x VGA cable
- 30.8 cm
- 21.1 cm
- 8.6 cm
- 2 kg
- Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
- Sound Emission
- 30 dBA
- Sound Emission (Economic Mode)
- 26 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
