Everything's better with more pixels. A high resolution makes textures crisp and clear. As you know, it's a resolution sweet spot for high-speed gaming. Acer monitor boasts a fast response time so all your fast-paced gaming action will be rendered smoothly without smearing, ghosting and motion blur. You'll be able to react and respond quickly to what you see onscreen - a definite advantage in the gaming arena. Acer monitor is equipped with an ultra-fast response time and low input lag technology for a lag-free experience. With low input lag I/O ports gamers can feel unparalleled super smooth visuals. Acer monitor shows your movements in real time.
BlueLightShield technology reduces the exposure of blue light, which can be potentially harmful, by adjusting color hue and brightness. You can access and select four different filter settings onscreen easily through the OSD menu to find the best one that suits the task at hand. Flickerless technology eliminates screen flickering by providing a stable supply of power to the display. This minimizes instances of eyestrain and other potentially damaging eye ailments when you're embroiled in long, drawn-out gaming sessions. ComfyView technology reduces the amount of light being reflected on your display for more comfortable viewing in various settings.
Much More to See
Take in the full view of the display with its ZeroFrame design atop the sharply-cut three-pronged stand. -
Lightning Fast Freesync
Discover the joys of a seamless game experience with AMD Freesync, up to 240Hz refresh rate a response time of 1ms. -
A Stand with Style
The stylish three-pronged stand saves on desk space without sacrificing style. -
ZeroFrame Design
The ZeroFrame design makes for a near-seamless look, allowing you to see more of what matters most: the screen. -
An Ergonomic Edge
Good monitors should cause little to no strain. With a tilt of-5° to 15°, you can put your mind, and your neck, at ease. -
Mount Up with VESA
Free up some of that desk area by mounting your display on the wall with VESA wall mounts. -
Yes, Resolution Matters
Choose from a wide range of resolutions from Full HD up to 4K UHD. -
Game with AMD FreeSync
Screen tearing will be a thing of the past with AMD FreeSync which syncs your display's framerate to the video card. -
Quick Response Time
A quick response of 1ms means images refresh quickly, making your gaming sessions seamless and enjoyable.
- Acer KG271U - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class G
- Energy Consumption per Year
- 39 kWh
- Power Consumption (On mode)
- 32.1 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440 at 75 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- 2xHDMI, 2xDisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 61.4 cm x 23.2 cm x 46.5 cm
- 4.5 kg
- Localisation
- Spain
- Environmental Standards
- ENERGY STAR Qualified
- MPR II, CCC, FCC, DDC-2B/CI, EAC, TUV Rheinland, NOM-NYCE
- 2-year warranty
- Display Type
- Energy Class
- Class G
- 39 kWh
- Diagonal Size
- 27"
- AMD FreeSync
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Anti-glare, Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame, Flicker-Less technology, Low Dimming technology, Super Sharpness technology, Acer VisionCare, Acer BluelightShield technology, 6-Axis Color Adjustments, 72% NTSC colour gamut
- Black
- 61.4 cm x 23.2 cm x 46.5 cm - with stand
- 4.5 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- 2 x DisplayPort , 2 x HDMI , Audio line-out , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- VESA interface support
- Cables Included
- 1 x DisplayPort cable
- Localisation
- Spain
- Input Voltage
- 32.1 W
- Power Consumption SDR (On mode)
- 32.1 kWh/1000h
- Power Consumption (Typical)
- 50 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- On / Off Switch
- No
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 10 - 85%
