Acer KA270HAbid 27" 1920x1080 VGA DVI HDMI Monitor
Quicklinx: CPFMWS00 Mfr#: UM.HX3EE.A01
The KA series is optimized for a comfortable viewing experience. The display is easy on the eyes with low response times and special technology to reduce glare and harsh blue light. Easy adjustments and a wide viewing angle help you find the perfect position.
Acer KA270H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Energy Consumption per Year
59 kWh
Power Consumption (On mode)
26.1 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
64 cm x 20 cm x 47.89 cm
MPR II, FCC Part 15, WEEE, DDC-2B/CI, Directive 2009/125/EC, EN 50564:2011, Directive 1275/2008/EC, EN61000-3-3:2008, RoHS 2011/65/EU, EMC 2004/108/EC, LVD 2006/95/EC, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN50581:2012, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, IEC 62301:2011, EN 55024:2010, EN 55022:2010 Class B
3-year warranty
Display Type
Energy Class
Class F
59 kWh
Diagonal Size
27"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Screen Coating
Anti-glare
Backlight Technology
LED backlight
eColor Management, Acer Adaptive Contrast Management (ACM), Acer Empowering Technology, Transition Minimised Differential Signaling (TMDS) technology
64 cm x 20 cm x 47.89 cm - with stand
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
Security Slot Type
Kensington security slot
Input Voltage
26.1 W
26.1 kWh/1000h
Power Consumption (Typical)
28.5 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
350 mW
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 64 cm - depth: 20 cm - height: 47.89 cm , Without stand - width: 64 cm - depth: 6.2 cm - height: 38.1 cm
Limited warranty - 3 years
CPFM StarTech.com Dual Monitor Mount - Stackable In Stock £226.92
CPFM StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
CPFM StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
CPFM StarTech.com Monitor Desk Mount - Steel In Stock £50.26
