Product
Brand
Acer KA240HQ 23.6" 1920x1080 5ms VGA DVI HDMI LED Monitor
Quicklinx: BK5DWS00 Mfr#: UM.UX6EE.A01
The KA series is optimized for a comfortable viewing experience. The display is easy on the eyes with low response times and special technology to reduce glare. Easy adjustments and a wide viewing angle help you find the perfect position.
Acer KA240HQ - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
56.7 cm x 19.2 cm x 43.46 cm
Microsoft Certification
Compatible with Windows 7
MPR II
Display Type
Energy Class
Class B
39 kWh
27 W
Diagonal Size
23.6"
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
56.7 cm x 19.2 cm x 43.46 cm - with stand
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
MPR II
AC 120/230 V
22 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption Sleep
0.35 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 56.7 cm - depth: 19.2 cm - height: 43.46 cm , Without stand - width: 56.7 cm - depth: 6.07 cm - height: 33.59 cm
BK5D C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BK5D C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.07
BK5D C2G 5m Select High Speed HDMI with Ethernet In Stock £16.55
BK5D C2G 10m Select High Speed HDMI with Ethernet In Stock £32.58
BK5D C2G 15m Select High Speed HDMI with Ethernet In Stock £43.69
BK5D C2G Pro HDMI to VGA Converter In Stock £49.56
BK5D C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
