Product
Acer KA240HQ 23.6" 1920x1080 1ms VGA DVI HDMI LED Monitor
Quicklinx: BQRNWS00 Mfr#: UM.UX6EE.B09
Diagonal Size: 23.6in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: None
Interfaces: DVI, HDMI, VGA (HD-15)
Hurry, only 1 left in stock!
£82.17 ex VAT
£98.60 inc VAT
Express delivery Order within the next 14 hours for delivery on Monday
The KA series is optimized for a comfortable viewing experience. The display is easy on the eyes with low response times and special technology to reduce glare. Easy adjustments and a wide viewing angle help you find the perfect position.
  • Optimized comfort
    Sit back and get comfortable with Acer ComfyView technology to reduce reflective glare and Blue Light Filter Pro to remove harmful blue light without sacrificing color or brightness. Get a good view with convenient -5° to 15° tilt adjustment.
  • Smart design
    On-screen display buttons are conveniently located on the front of the device for easy access. The KA series is wall-mountable and has space for a Kensington lock for added security.
Acer KA240HQ - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
56.7 cm x 19.2 cm x 43.46 cm
Microsoft Certification
Compatible with Windows 7
MPR II
3 years warranty
Display Type
Energy Class
Class B
39 kWh
27 W
Diagonal Size
23.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
56.7 cm x 19.2 cm x 43.46 cm - with stand
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
MPR II
Security Slot Type
Kensington security slot
AC 120/230 V
22 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 56.7 cm - depth: 19.2 cm - height: 43.46 cm , Without stand - width: 56.7 cm - depth: 6.07 cm - height: 33.59 cm
Limited warranty - 3 years
Acer KA240HQ 23.6 Bundle deal on Acer KA240HQ 23.6" 1920x1080 1ms VGA DVI HDMI LED Monitor
£177.18
Accessories (6)
BQRN StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £103.98
BQRN StarTech.com Articulating Monitor Arm In Stock £96.76
BQRN StarTech.com Dual Monitor Stand In Stock £69.73
BQRN StarTech.com Cubicle Monitor Hanger In Stock £43.71
BQRN StarTech.com TV/Monitor Arm - Wallmount In Stock £59.78
BQRN StarTech.com Monitor Arm - Heavy Duty In Stock £69.15
Other bundles (4)
BQRN C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BQRN C2G 5m Select High Speed HDMI with Ethernet In Stock £20.88
BQRN C2G 15m Select High Speed HDMI with Ethernet In Stock £54.29
BQRN C2G Pro HDMI to VGA Converter In Stock £50.07
Response Time: 1ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 50 - 100
